Latest post Mon, Nov 16 2009 12:43 PM by Larry Rubin. 7 replies.
  • Fri, Nov 6 2009 1:20 AM
    • Mhawkes
    • Joined on Thu, Oct 29 2009
    • Posts 1
    • Points 15
    Help! Problems with Capturing Video from Sony HDV Camera
    Hello!
    I am a newbie at editing and capturing using Avid Media Composer. I borrowed a camera from work, the Sony HVR-HD1000U, although Avid doesn't have an exact configuration for the camera, we use the Sony DCR-PC120 setting at work and it captures fine. I tried using this setting at my own computer at home and it isn't reading it and always says No deck. I am using a firewire to connect it to my HP computer. Any feedback? Help...please?
  • Fri, Nov 6 2009 1:49 AM In reply to
    Re: Help! Problems with Capturing Video from Sony HDV Camera
    Hello, and welcome to the Forum! Please take a few moments to fill out your system specifications. Click on your name, then "edit my profile" and then "profile options" to get to the appropriate text field. We need this information to help you.
    In the meantime since you can't find the exact model in the Sony templates, can you confirm that you've tried configuring a channel with "Firwire on OHCI" linked to an appropriate generic dv template?
  • Fri, Nov 6 2009 1:24 PM In reply to
    • clmt
    • Joined on Fri, Nov 6 2009
    • Posts 2
    • Points 50
    I have the same problem! But i think this is not an AVID problem, but windows.
    I'm using Sony HVR-Z7 Camcorder on VIA OHCI-konformer 1394-Hostcontrolle.
    AV/C Subunit driver doesn't work, i see it  as "?" in hardware manager :( And I have no idea how to install it.
    msdv.inf and msdv.PNF are on the right place in c:\windos\inf folder. but it dosen't workSuper Angry
    sorry for my english, i do my best! Hmm
    * XP Pro SP 3 * Composer v3.1.2 * Quicktime v7.6.4 * mainboard: MSI K9Ndiamond 2GB RAM 2 Drives: st3250620as (Seagate Barrakuda 250GB... [view my complete system specs]
  • Fri, Nov 6 2009 2:12 PM In reply to
    Please mention in your system description the type of HP computer and in this case what kind of firewire card you use.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Fri, Nov 6 2009 3:15 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    clmt:
    Your prob is most likely that you are using a VIA chip for your firewire connection, buy a Texas Instrument one instead.
    Some other comments to your profile would be that you are using an uncorrect version of QT for the version of MC that is inside your profile.
    Tomas
  • Mon, Nov 16 2009 7:07 AM In reply to
    • clmt
    • Posts 2
    • Points 50
    thx mjolnarn. you seems to be right.
    hmm... i always download the latest version from QT site.
    which one could be the right one? and where can i get it? Confused
  • Mon, Nov 16 2009 7:25 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    You´re welcome, nice to be able to help.
    About versions of Quicktime, doing a search in the knowledge base for version matrix gave me this
    edited ...  and that document is also linked from the first thread on this forum of course ...
    just noticed ..Embarrassed
    Tomas
  • Mon, Nov 16 2009 12:43 PM In reply to
    Clmt:
    Be advised that the latest QT version is not necessarily the correct one for you. As per the version matrix, you should be running QT 7.5.5 not QT 7.6.4. You can get earlier versions of QT here.
