Latest post Mon, Nov 2 2009 7:50 PM by Johnla. 76 replies.
Page 2 of 6 (77 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Sat, Oct 3 2009 5:51 PM In reply to
    Re: MC 4 not shutting down correctly after BCC 6.0.5
    Have you updated your Quadro drivers with the new supported?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sat, Oct 3 2009 6:06 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,756
    • Points 62,020
    sverkalo:
    Yes - thanks - they're the same for this release as for 3.5.4.
    When considering this issue, remember that my system works perfectly with MC 4.0.2 and BCC 6.0.4 so it's not obviously a problem with my system so much as an incompatibility with some change Boris made between 6.0.4 and 6.0.5.
    Also - and I know this didn't affect Tomas' install - but the fact that the BCC 6.0.5 patch didn't install in an 'as expected' manner has me wondering if the patch itself is incomplete.
    Thanks guys,
    Cheers
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Oct 5 2009 3:49 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    Barkin,
    Just curious.  Have you tried the typical troubleshooting steps. New project user etc?   Do you you still get this behavior?  I'm going to do some testing of this today but I am not sure if i have this graphics card in house so I want to make sure you've taken the standard troubleshooting steps.
    Also there was some concern on how the installer ran.  It is not a "patch" installer.  It is a full version of the software.  That is why it runs as a full version of the isntaller...shouldn't be causing this issue anyhow.  Just wanted to clear up the that installer behavior is normal and nothing to be of concern.
    -Matt M.
  • Mon, Oct 5 2009 5:19 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    I am up running 4,02 and 6,04 / 6,05 with V64 SP2 for a test in an hour or two, has just cloned a bootdisc.
    Tomas
  • Mon, Oct 5 2009 6:34 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,756
    • Points 62,020
    mmullen:
    Barkin,
    OK - so as a full installer, would you expect that the best approach to installing BCC 6.0.5 is to first remove the previous BCC installation? The very fact that the BCC 6.0.5 installer wanted to 'repair' the installation suggests that the installer has not been updated to understand that it should do a full install over 6.0.4 (that's what I would expect, anyway).
    To answer your question - I did create a new project to test this issue, but not a new user. I'm now in the middle of some work so I won't be able to try an installation of BCC 6.0.5 for a while. Sorry.
    Steve
  • Mon, Oct 5 2009 6:35 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,756
    • Points 62,020
    Tomas,
    How did you install BCC 6.0.5? Using the 'Repair' option?
    Steve
  • Mon, Oct 5 2009 6:49 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    BarkinMadd:
    Tomas,
    Yes, both from 6,02 I believe, the very first version, to 6,05 and then back again and then up to 6,05 again
    Tomas
  • Mon, Oct 5 2009 7:19 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    There should be a modify choice, that is what you should choose when installing.  In your case where you are having issues yes I would recommend removing first.  This would help to rule out any type of installation issue.
    -Matt M.
  • Mon, Oct 5 2009 7:22 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    If I choose modify, nothing happens on any of my sys
    Tomas
  • Mon, Oct 5 2009 7:52 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    If thats the case I would uninstall/reinstall just to make certain it is writing the files.
    -Matt M.
  • Mon, Oct 5 2009 8:08 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Repair works well, both ways, when it is about downgrading / upgrading between the different versions of BCC 6 , if you update from BCC 5 to BCC 6, an uninstall of BCC 5 is needed before installing BCC 6.
    And, I am up and running 4,02 / BCC 6,05 now, no shutdown probs, sys as in profile below.
    Bed is waiting ....
    Tomas
  • Tue, Oct 6 2009 8:56 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    FYI I did the full WU, letting windows decide what was needed so that included IE8, seems to work well all of it audio scrubbing included, anything you want me to test Steve?
    Tomas
  • Tue, Oct 6 2009 11:40 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,756
    • Points 62,020
    Hi Tomas,
    IE 8 is OK with 4.0.2? interesting.
    As far as testing - all I did was create a new project, insert some HDV footage on to the timeline, slice it up into a few sections and place the BCC extruded text filter on to one of the segments and then added some text to the effect. That seemed to be all that was needed to cause problems shutting down.
    This exact same test with BCC 6.0.4 did not produce any problems for me. Would you mind trying this simple test? Thanks.
    Steve
  • Tue, Oct 6 2009 11:56 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    I tried Boris Uprez filter and Optical stabilizer yesterday, this on HDV clips and thin raster, will try the extruder in a couple of hours
    Tomas
  • Tue, Oct 6 2009 12:54 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,756
    • Points 62,020
    Thanks Tomas. I'm thinking OpenGL + FX 3700 + Vista 64 + BCC 6.0.5 + MC 4.0.2
    or.. it's just my system. If I had the time, I would do a complete system rebuild. In the mean time, if no one else with my configuration is having troubles with this... that's great for them - Stick out tongue
    Cheers
    Steve
