Latest post Sat, Aug 29 2009 6:03 PM by Abeyta. 7 replies.
  • Tue, Aug 18 2009 10:40 PM
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    HDCAM Closed Captioning
    Anybody know how to set up the menu on an HDCAM HDW D1800 deck so it will record HD Closed captioning data? I'm not creating the CC just want to be able to record the CC data from a CC hardware encoder onto HDCAM tape for a PBS Documentary delivery. I believe you have to turn something on in the deck to do this and the manual doesn't have any information on this.
    From the PBS TOS submission form:
    For High Definition submissions, CEA-708-C
    captions with "608 compatibility bytes" must be
    carried in the ancillary data space (ANC) per SMPTE
    334M-2000.  The captioning ANC data must be
    present on line 9.
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Tue, Aug 18 2009 10:49 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    Re: HDCAM Closed Captioning
    It's embedded in the ancillary data by the hardware box. I don't believe you have to turn anything on in the deck.
    Do a test and check the deck out on a CC aware monitor.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Tue, Aug 18 2009 11:07 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Thanks Terence,
    I'm just researching now. I don't have the CC box here. I don't know where I read that you had to turn something on in the menus. I'll try to figure out where I heard that and post back.
    By the way I sent you an email the other day with some questions for you about your company. Did you receive it?
    Derrick
    Phoenix, Arizona
  • Wed, Aug 19 2009 12:20 AM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    http://forums.creativecow.net/thread/98/865858#865873
    Found this on the Cow. Does this make any sense?
    Phoenix, Arizona
  • Wed, Aug 19 2009 2:43 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    Abeyta:
    No. Did you send it to TCurren(at)AOL.com
    Burbank, Ca
    www.alphadogs.tv
  • Wed, Aug 19 2009 2:56 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    Abeyta:
    Potentially. It makes sense that you could blank lines of information in the ancillary data. It's nice that Sony makes it so easy to understand in their manual... ;-)
    I have the 5500 and the 5800 decks. So I'm not sure what is on the 1800. I would unblank all the incoming lines on the VTR per the link you found. Then make sure the caption box or software is set to place it on line 9 per the delivery requirements.
    Why this setting is hidden in a maintenance menu is ridiculous.
    Burbank, Ca
    www.alphadogs.tv
  • Wed, Aug 19 2009 10:34 PM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Studio City, CA
    • Posts 397
    • Points 4,465
    It's in a maintenacne menu because it's Sony.  Why is the 4 channel vs 8 channel on an IMX deck require a dip switch to enable entry into the maintenance menu to get to the oh so obviouse Data length or some such name to change from 4 to 8 channels?
    Symphony Nitris and Nitris DX 4.x and MCsoft 5.x & 5.5x, MCsoft 6, Artist Color [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
  • Sat, Aug 29 2009 6:03 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    These settings I found on the creative cow ended up working fine.
    In the HDW-1800 deck:
    Enter the maintenance menu:
    1/ Alt - f9
    2/ MAINT MODE/OTHERS/VANC RX PARAMETER
    (For 708 Compliant CC)
    Line 1 Line 2 DID SDID
    009 572 61 01
    3/ Don't blank any lines
    Phoenix, Arizona
