Latest post Wed, Aug 19 2009 12:31 PM by Larry Rubin. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Aug 18 2009 7:01 AM
    • lucasino
    • Joined on Sun, Aug 16 2009
    • Posts 12
    • Points 190
    More Questions About White Screen
    I got the Free DV, running on Vista (though I know I shoudn't) and then I get everything up perfect. I try to import both AVI and MOV files into the bin. I get a white screen both times. I have got an older version of QuickTime and tried them again. Didn't work again. I am also just using my C: Drive. (I know that's not proper either). Can I get some help?
  • Tue, Aug 18 2009 7:25 AM In reply to
    Re: More Questions About White Screen
    You get the white screen when the codec for that QT file is not installed on your system.
    At desktop level, open the file in QT player, then hit CTRL-I. QT player will tell you what codec was used. Make sure you get this codec installed. If the codec is not available, then try downloading VLC player and try to stream the file into a codec that your system can play back. Then you should be able to import into Avid.
  • Tue, Aug 18 2009 5:03 PM In reply to
    • lucasino
    • Posts 12
    • Points 190
    Which codec do I need for it? And I have VLC. How exactly would I do that method? and is there a way I can get my perfectly okay AVI files to go in?
  • Tue, Aug 18 2009 5:18 PM In reply to
    lucasino:
    That depends on the codec with which the file in question has been encoded. So to find out:
    Job ter Burg:
    lucasino:
    Avi, like Quicktime, is a container format. Almost anything can be inside it. Avid needs to convert any files you want to use to Avid mediafiles, with a specific codec, framerate and size. Your AVI files may be "perfectly okay", but the question is: what flavour are they?
  • Tue, Aug 18 2009 7:13 PM In reply to
    • lucasino
    • Posts 12
    • Points 190
    Alright. When I tried to figure out which codec is on the Quicktime and I did the Ctrl+I, I didn't get a lot of info, and none of which is on the codec.
    If I have MediaCoder, and I ripped a part of my DVD that I want to into AVI video and Xvid, what is the actual specs that would make it work in AVID? What can I do in mediacoder that would make it so I will have less problems?
  • Tue, Aug 18 2009 7:20 PM In reply to
    lucasino:
    What did it say after "Format:"?
    I don't know MediaCoder, so I don't know what formats it will spit out, but if you can make something like DV25 out of it (either in an AVI or a MOV container), that should import very well into the Avid.
  • Tue, Aug 18 2009 7:57 PM In reply to
    • lucasino
    • Posts 12
    • Points 190
    It didn't tell me format in the information thing. I want to just forget about that part. I tried DV Video format in a AVI container, and it didn't work. What was the VLC thing that I could have done?
  • Tue, Aug 18 2009 8:18 PM In reply to
    lucasino:
    That's weird. Does the file play back on your system?
    VLC can do a transcode, but I think it won't make DV25. My first idea would be to check if your MovieCoder can export as DV25. If not, try QuickTime Pro and export to DV-PAL or DV-NTSC (depending on the source).
  • Wed, Aug 19 2009 12:08 AM In reply to
    • lucasino
    • Posts 12
    • Points 190
    I am all confused again. I just want to convert my AVI files into a format that can be read on AVID so I can edit. What is the easiest way? (Besides getting Quicktime Pro, because I have absolutely no money) (I am sorry, I get confused easily)
  • Wed, Aug 19 2009 1:02 AM In reply to
    lucasino:
    If I couldn't scrape together $30, I'd have much bigger issues than not being able to import clips to edit with.
  • Wed, Aug 19 2009 1:49 AM In reply to
    • lucasino
    • Posts 12
    • Points 190
    I am fifteen. I am a young person. I am sorry. But can you please help?
  • Wed, Aug 19 2009 2:03 AM In reply to
    Job gave excellent advice -
  • Wed, Aug 19 2009 2:25 AM In reply to
    Lucasino:
    Here is a link to a free downloadable converter program MPEG Streamclip. Hopefully, you can use it to convert what you have to a Quicktime movie file, which is supported by Avid for import.
  • Wed, Aug 19 2009 3:38 AM In reply to
    • lucasino
    • Posts 12
    • Points 190
    YES! Thank you very much. I did the conversion with the MPEG Streamclip, and it worked perfect. It exported a really big file, but I really don't care. It works. Many thanks.
  • Wed, Aug 19 2009 12:31 PM In reply to
    You're quite welcome. Glad that solved your problem in an "affordable" manner!Wink
