Dears,
Can we insert flash objects into DekoCast scenes?
Regards
Though there may be a way to get a flash object into DekoCast via creating your own program or script (that is beyond me) DekoCast is not designed to use flash objects.
Try creating your animation as a series of .tga for a cell animation (rendered to the size you need, a good starting point for SD is 200X200 with 200 frames) or as an .mov file (rendered to the size of your output resolution, i.e. 720X480 for SD).
