Latest post Tue, Feb 14 2012 5:18 PM by Richard Ward. 7 replies.
  • Sun, Jun 28 2009 6:54 PM
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
    changing & saving project settings in Avid Xpress DV
    When I search for this I am only finding help for later Avid systems...not Xpress DV...and the manual is not making it clear to me.  The main project setting I'm concerned about right now is the media creation settings.  I want every project to automatically put its media in a specific place.  While in Avid I click on Settings/media creation/....and I assign my drives for that project.  To make it easy I filter out the launch and system drives and assign all media to, say "K.".(for that project)
    first question...how do you save that project setting for that job so that when you come back in the media creation will be correct?  Right now, after making the change, I go to the file menu and click "save all."  Then, when I exit Avid and come back into that particular project, it has defaulted back to the old media creation drive.
    2nd question:  What's the point of "file/new setting file?"  All you get is a white window named "untitled?"  You can't click in it; you can't change "untitled" to any name.  It just sits there.
    If somebody could take me through the process of changing my media creation settings for a particular project....so that they don't revert back...that would be wonderful.
    Kay
    Dell Precision 340 Workstation Win XP Pent 4, 1.80 Ghz 512 MB ram ACPI Uniprocessor PC Disk drives: IC35l120 avva07-0 SCSI (x2) Prolific PL3507... [view my complete system specs]
  • Sun, Jun 28 2009 7:07 PM In reply to
    Re: changing & saving project settings in Avid Xpress DV
    Kay:
    The blank window you're seeing is the site settings window and the answer to your problem. Any project setting that you want to apply globally you simply drag that setting into the site settings window. So you would drag your media creation settings there. However, be advised that there is a long standing anomaly that results in media creation settings NOT being consistently honored as site settings. So always double check your destination drives everytime you render, import, capture, create titles, and do mixdowns.
  • Sun, Jun 28 2009 9:02 PM In reply to
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
    Larry -
    Thanks so much!  I'll try that but since my last post I really ran into a problem that I'll post with a different heading.  Thanks again...
    K
  • Mon, Jun 29 2009 7:34 PM In reply to
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
    it worked!  At least one thing good happened today.
    Thank you...
    K
  • Mon, Jun 29 2009 7:36 PM In reply to
    You're quite welcome. Always glad to help out.
  • Tue, Feb 14 2012 5:11 PM In reply to
    I have a student who accidentally imported and edited NTSC 30i footage as a PAL project. Is there any way to change the project setting from PAL to NTSC, or to import the footage and timeline into a new NTSC project?
    HP HPE-410t, Quad Intel Core i5 2.8GHz, 64 bit, NVIDIA GeForce GT 420, 1Tb system drive, 1Tb data drive [view my complete system specs]
  • Tue, Feb 14 2012 5:18 PM In reply to
    The project cannot be switched.  If you have a newer version of Media Composer, it can mix frame rates.  So, you can start an NTSC project, and then open the Bins from the PAL project.
    (wwld)
    OK. Thanks.
