Latest post Wed, Jun 17 2009 6:46 PM by Doc Avid. 3 replies.
  • Tue, Jun 16 2009 5:35 PM
    • Pablo
    • Joined on Thu, Jan 17 2008
    • Buenos Aires
    • Posts 12
    • Points 190
    SystemDirector metadata backup...
    Due to a virus, I need to install a Windows patch on both SystemDirectors, which is fully supported by Avid. But, I want to make a metadata backup, just in case...
    Where can I found the file/s?
    Thank you!
    #1 Unity: 10 Adrenaline clients, for post. #2 Unity: 14 Eth NCXP, 4 ingest stations, 16 AirSpeeds (12 ingest, 4 playout). Many, many Mojos. Used for News... [view my complete system specs]
    Pablo
  • Tue, Jun 16 2009 6:59 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,321
    • Points 25,890
    Re: SystemDirector metadata backup...
    Your total metadata is not on the SD-  only partial,  some is on the storage.
    What patch-   I may have already done it.   And-  in a 2 SD environment,  you can patch the standby,  fail over, then patch the new "standby"
    JDS
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
    Filed under: , ,
  • Wed, Jun 17 2009 2:18 PM In reply to
    • Pablo
    • Buenos Aires
    • Posts 12
    • Points 190
    That´s what I wanted to do: patch the standby one, trigger a failover, then work again on the current standby. If the patch is supported, nothing should happen.
    The MS Windows patch is "KB958644" (Google it). It prevents remote code execution; what makes me doubt about the installation is the fact that MS doesn´t seems to provide a Windows XP Embedded version of the patch, just SP1, SP2, etc.
    That´s why I want to backup my metadata before doing something I can regret.
    So, again, how can I backup my SysDir metadata? and do you have any info about this patch?
    Thank you in advance.
    Pablo
  • Wed, Jun 17 2009 6:46 PM In reply to
    • Doc Avid
    • Posts 2,321
    • Points 25,890
    D: program files / Avid /Avid Unity ISIS/
    Get partition0, Partition1, Partition dump.bin
    Back it up,  but only use in case of a failure-   you should have no problems putting the patch in.   I put it in last fall, with no problems.
    JDS
