Latest post Sat, Jun 13 2009 7:03 PM by MichaelP. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Jun 8 2009 3:37 PM
    • Synchro
    • Joined on Mon, Jun 8 2009
    • Posts 4
    • Points 40
    24 FPS HD Digi --> 25 FPS SD PAL Digi --> 24 FPS Project and EDL for Reconform
    Hi guys,
    We received a feature film on a 24 fps HD Digi (may be 23.97 exactly) that we downcoverted to a 25p fps SD PAL digi so that we could take the footage into our Avid Adrenaline System (which does not support HD footage) and create a 2-min trailer. We imported the footage into a 24 fps project, from which we would then export a 24 fps EDL that we could use to reconform the HD footage in an online suite. However, it doesn't work! Please could you advise if this is a possible workflow, and if so, how to make it work? If not, what would you do?
    Many thanks for you help!
    Filed under: , , , ,
  • Sat, Jun 13 2009 7:03 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,415
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    Re: 24 FPS HD Digi --> 25 FPS SD PAL Digi --> 24 FPS Project and EDL for Reconform
    What part doesn't work? Steps are:
    HD24 Master
    Downconvert to SD as a 4.1% speed up
    Capture in PA 24p SD project (timecode is now 25fps)
    Highlight START column and command-D/control-D into the TC24 column
    Select "convert" from the dialog box that pops up
    Create EDL based on that column for conform.
    Michael
    24p.com
