Latest post Sat, May 16 2009 5:46 AM by Doc Avid. 4 replies.
  • Tue, May 12 2009 2:18 PM
    Too many files in this workspace?
    Using Unity Medianet 5.0.1 with three XP fibre clients (MC).  I've got a workspace called Resources where we keep graphics, fonts and files commonly used every day in all our projects.  In Unity's admin tool the workspace currently has 11729 files although it's a very small workspace compared to other workspaces containing Avid media.  I remember reading somewhere on in this forum that a workspace shouldn't have more that 10000 files...is this correct? I'm not experiencing any problems at the moment, need I be worried?
    Avid Media Composer 2020.4 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Tue, May 12 2009 4:55 PM In reply to
    • Posts 11,311
    • Points 232,440
    Re: Too many files in this workspace?
    Hey there CorneScheepers....
    What I do know is that due to the block size on the Unity Filesystem of 1024k, a file with the size 1 KB will actually take up 1024k (1MB) on the drive.  If the file is growing in size, it does not take up more space on the drive until it reaches the 1024k size.  Here is a good document to read as it outlines file sizes wtc...
    http://www.avid.com/cgi/kbase-redir.aspx?p_faqid=76688
  • Tue, May 12 2009 5:59 PM In reply to
    • briMestone
    • Joined on Fri, Nov 18 2005
    • San Francisco
    • Posts 140
    • Points 1,570
    CorneScheepers, as far as i know the 11k+ in "one Partition" is fine as long as the files are separated by multiple directories.
    OMFI MediaFiles>
    1. Edit_Bay_1
    2. Edit_Bay_2
    3. Edit_Bay_3
    and so on.
    the number of files that can reside in a single directory is based on the Filesystem (Avidfs) ei. in my situation  i always keep it below 2k so it will scan media files faster for maintainance.
    You wont see any problem in the near future as long as your far from 500,000 files total inside your unity.
    6 ISIS5000 split in two environments, 25 MC7+SYM NitrisDX, MacPro3,1 MacPro4,1 [view my complete system specs]
    Ted Simbajon
    http://www.tedsimbajon.com
    Head Janitor
  • Wed, May 13 2009 3:36 PM In reply to
    Thanks for the replies everyone.  I'll check out the link Marianna, thanks.
  • Sat, May 16 2009 5:46 AM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,321
    • Points 25,890
    Modern Unity and Composer systems spread the files among folders AUTOMATICALLY.
    If you have too many files in the OMFI Media files/AVID1 folder,  it will make another folder called AVID1.1
    same goes for MXF folders.   The number of files varies in a folder varies between 2500 and 6000, depending on the particular rev of Composer.
    The 10K figure you are quoting is the folder count limitation,  and the 500K file limit mentioned is the file limit.   The two are a bit flexible, provided you don't top both numbers.   I've seen operating systems with 12K folders, but only 300K files,  so it doesn't go over what the metadata memory space can handle.
    It has been recommended however, that workspaces not go over 300 Gigs in size.
    If you are manually screwing around with files counts, or these are not media files managed by a media composer, then you are asking for trouble on both accounts.
    JDS
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
    Filed under: , ,
