Latest post Tue, May 5 2009 4:56 PM by BLKDOG. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Apr 23 2009 1:36 AM
    • samvideoman
    • Joined on Mon, Oct 9 2006
    • Virginia
    • Posts 87
    • Points 1,220
    Unity Media Net Server
    I have a unity media server file manager, it has two fiber channel cards installed. I have a Media Dock with 8 drives. I would like to know what else would i need to connect this system to a symphony v5 mac with fiber channel card, and a Media Composer software v3 PC..
    Sam King
    Avid Media Composer Software v3 running on MacBook Pro. [view my complete system specs]
  • Thu, Apr 23 2009 2:08 AM In reply to
    Re: Unity Media Net Server
    The MediaDock is SCSI, not fiber.  Just curious, how did you end up with a File Manager, and no fiber storage?
    What type & version of File Manager?  You'll need fiber enclosure(s) and fiber drives, a fiber switch, fiber cables .....
    (wwld)
  • Thu, Apr 23 2009 3:08 AM In reply to
    • samvideoman
    • Virginia
    • Posts 87
    • Points 1,220
    got it on ebay. so i will need fiber storage, switch, and fiber cables... should that do it? I belive it's v 4.1
    thanks
  • Thu, Apr 23 2009 3:24 AM In reply to
    "... so i will need fiber storage, switch, and fiber cables ..."
    You need "Avid" fiber drives, because they have the proper firmware on them.  You need the Avid approved fiber switch so the Avid-provided firmware and switch configurations (port zoning) will work.  You need the correct make/model of fiber cards in the clients, loaded with the Avid-provided firmware & drivers.
    Does the File Manager have a dongle on the back?  If it's v4.1, then it would be attached to the parallel port.
    (wwld)
  • Thu, Apr 23 2009 2:41 PM In reply to
    • samvideoman
    • Virginia
    • Posts 87
    • Points 1,220
    i see so a little more to it. Thanks for the info :-)
  • Thu, Apr 23 2009 4:27 PM In reply to
    "... i see so a little more to it .."
    Yeah, there is.  Just a an FYI. the Unity ACSR Certifiction Course is 5 days.  Even for those of us that are certified. the setup is extremely detailed.
    (wwld)
  • Thu, Apr 23 2009 4:42 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Not only that but MC 3.5.x is not qualified on a Unity 4.0 setup/client.
  • Thu, Apr 23 2009 4:54 PM In reply to
    Well, yeah, there's that too :)
    (wwld)
  • Thu, Apr 23 2009 5:27 PM In reply to
    • samvideoman
    • Virginia
    • Posts 87
    • Points 1,220
    Thanks for all the info, it will help me keep sane:-)
  • Tue, May 5 2009 4:20 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,321
    • Points 25,890
    BLKDOG:
    That statement is NOT true.
    Media Composer 3.5 for XP, Vista and Leopard (10.5.5 / 10.5.6 ) is qualified to use Unity 4.1.6  4.2.4 and 5.0.1    Page 11, release notes for Composer 3.5.
    Since the OP believes his system is Unity 4.1,  he'll be fine with 4.1.6.
    And--  Since most don't consider Unity 5 qualified for any 100% Uptime environment, such as Broadcast-  there will be serious problems the day that Composer will not use Unity 4.x
    JDS
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
    Filed under: , ,
  • Tue, May 5 2009 4:56 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Actually, at the time I wrote that, I was under the inpression that this was 4.0, not 4.1 and, at that time, we had not qualified 3.5 on Unity 4.0.
