Latest post Thu, Apr 23 2009 4:04 AM by Ervz Tia (Tikboy). 4 replies.
  • Wed, Apr 22 2009 10:00 AM
    Resolutions for Capture/Import
    Please enlighten me.
    Is there a benefit for capturing DV materials to half or even lower reoslution? Say, I am initially woring with a laptop and a small USB drive but plans to upres and finish on a full system.
    Also, please explain the different reslutions available. Which ones goes up/down?
    Thanks!
    Ervz Tia | Video Productions
  • Wed, Apr 22 2009 11:01 AM In reply to
    Re: Resolutions for Capture/Import
    If you've got limited drive space, capturing at a lower resolution and finishing at a higher resolution is a good way to go.  Also, if you're cutting initially on an underpowered machine with a USB drive, you could get better performance using lower resolution media.
    good luck,
    Carl
    Media Composer 2020.10 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Thu, Apr 23 2009 2:53 AM In reply to
    Thanks Carl!
    Now, please explain the different ratios and resolutions (attached). In othere words, which ones goes lower and which ones goes higher?
  • Thu, Apr 23 2009 3:21 AM In reply to
    tikboy:
    Aren't most of them obvious?
    1:1 obviously applies the least amount of compression to the footage being captured. (SD 601/D1)
    1:1 10b is the 10-bit version of 1:1
    2:1 applies 2 times as much compression as 1:1
    3:1 applies 3 times....
    The "s" resolutions are single field (so they are effectlively only capturing half of the image (and compressing it)
    "m" resolutions were typically used for Multicam because they compress the footage in a way that optimizes it for Multicam (they're not totally necessary these days)
    DV25 and DV50 are the DV resolutions (720x480 in NTSC), the 25 and 50 represent the Mbit/sec.
    DV50 is half as compressed as DV25
    DV25 is generally considered comparable to "5:1" in terms of ratio.
    MPEG30/40/50 are actually Sony's IMX resolutions in the their 30, 40, and 50 Mbit versions.  I don't know for sure where they fall in terms of ratio, but MPEG50 is generally acceptable by most broadcast standards.  YMMV.
    You can also determine the amount of compression by looking at many hours your drives will capture as you select the various resolutions in the Capture Tool.  The more hours available, the more compressed the resolution.
  • Thu, Apr 23 2009 4:04 AM In reply to
    Thank you for the clarification. Sorry, I did not have much opportunity to work with a wider medium and formats. It's just DV and HDV, no offline/online stuff.
