Latest post Fri, Apr 17 2009 10:04 PM by Abeyta. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Apr 17 2009 5:30 PM
    • snappyg
    • Posts 12
    • Points 170
    Import FCP clips
    We are going to import some FCP clips of different resolutions into MC 3.5. Some are HD, some are not.
     Does this look like a good workflow?
    Import the clips into QTpro with FCP & Avid codecs installed> Export the clips with avid codec, or, make QT reference files with the Avid codecs, or use animation settings in QT on expot.
    Cheerio!
  • Fri, Apr 17 2009 5:47 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Re: Import FCP clips
    Might want to try this.
    http://www.automaticduck.com/products/
    Dual 2 GHZ MAC.6 gig ram,3 gig hard drives, Avid w/ MOJO, FCP, Motion MBP Intel core 2 Duo,2.6 GHZ 4 gig ram, 17 inch Matte screen, Avid w/Mojo, &... [view my complete system specs]
    Filed under: , ,
  • Fri, Apr 17 2009 5:48 PM In reply to
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 518
    • Points 5,965
    If it were me I would use the Animation codec.  Is maintaining timecode a concern?
    Media Composer 8.3.1, OSX 10.9.5 [view my complete system specs]
  • Fri, Apr 17 2009 6:33 PM In reply to
    pianoman72:
    But, if you use an Avid codec, then it'll at least be a "Fast Import".
  • Fri, Apr 17 2009 8:56 PM In reply to
    • snappyg
    • Posts 12
    • Points 170
    Maintaing TC is not an issue.  Also the Duck is not an issue as the clips are not cut. Just want to use the FCP clips and cutem'.   So QT reference clips , then export with Avid codec.  Cheers!
  • Fri, Apr 17 2009 8:59 PM In reply to
    • snappyg
    • Posts 12
    • Points 170
    Duh - Why bother with the QT refs. I'll just export em with the codec.
  • Fri, Apr 17 2009 10:04 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    MC version 3.5 now imports/exports quicktimes with embedded timecode. So you shouldn't lose TC info
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
