Latest post Wed, Apr 1 2009 10:47 AM by mjolnarn. 7 replies.
  • Fri, Mar 27 2009 7:02 PM
    • JohanD
    • Joined on Fri, Dec 1 2006
    • Netherlands, Hilversum
    • Posts 7
    • Points 85
    Video output on second monitor
    Fist i want to apologize for my bad english!
    I use Avid Media Composer 3 on my notebook.
    On location i capture the source material straight from the camera through the firewire.
    When i start to edit and the camera is still conected to the pc i see my active material in Avid back on the LCD screen of my camera. So, i can use the LCD screen of the camera as a second monitor.
    Now the thing is that Avid only puts out still images, so when i pause my sequence he displays the actual frame on the camera LCD. So when i play my sequence the LCD is black. But when i manual drag through the sequence he can display it in motion!
    The nice thing about watch the material realtime back on de camera is that i can connect the cam on a external monitor, and can i watch back my video whitout using a MOJO on location.
    Does anybody know why Avid outputs black by playing video?
    Or is there a simple option to fullscreen output the sequence video to a second monitor through the notebooks VGA or HDMI output?
    Thanks!
    I'm using a Vista Notebook
    whit a Nvidia Geforce 8400M GS graphical card.
    And a Camera connected by Firewire
    Avid MC, Windows Vista, Nvidia Geforce 8400M GS, Intel Core 2 Duo 2.00Ghz [view my complete system specs]
    www.JohanDijkstra.com
  • Sat, Mar 28 2009 2:00 PM In reply to
    Re: Video output on second monitor
    JohanD:
    If you have no DNA such as Mojo, Adrenaline, Nitris connected you can have a fullscreen playback with the shortcut strg+shift+f (windows). There is a tab in the settings called "Full Screen Playback" where you can choose a monitor which should be used to run FSP.
    JohanD:
    This sounds like having an ATi- or other unsupported GPU. In that case you can watch this behaviour on your main display... Confused But that's not the case here. Anyone any ideas? I like the idea of getting an old, cheap MiniDV + an old, cheap CRT to see my output there.
    greetz, g_f
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
  • Sat, Mar 28 2009 2:08 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    What about a Canopus Bob instead, and a cheap SD plasma that nobody wants to have any longer
    And, as you can see, it is in colour
    Tomas
  • Sat, Mar 28 2009 2:15 PM In reply to
    Well... yes. Saw that before here in the forum, nice setup, btw. But we are both notebook users and might prefer a more mobile variant. Big Smile
    Btw: a plasma can't display fields, or am I wrong? I thought a digital display (LCD or plasma) get a deinteralced image from a digital TV-receiver? Correct me if I'm wrong.
    g_f
  • Sat, Mar 28 2009 2:23 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    JohanD:
    I believe that this prob comes from that you are playing media that is changed or edtited in some way and needs to be rendered.
    Go to settings - Video Display settings and checkmark " realtime Encoding " and see if that helps
    Tomas
  • Sat, Mar 28 2009 2:41 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    general_failure:
    Thanks for that and about using it to test field issues, I really haven´t thought about it, using it for common previewing, it works for previewing with both MC , AE snd Liquid
    Tomas
  • Wed, Apr 1 2009 10:32 AM In reply to
    • JohanD
    • Posts 7
    • Points 85
    general_failure:
    Thanks! The fullscreen playback on the second monitor works fine!
    mjolnarn:
    Wow!
    Works fine! There only is some delay, but this whould always be there by using firewire.
  • Wed, Apr 1 2009 10:47 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Very good
    Tomas
