Latest post Sat, May 16 2009 9:34 AM by John Moore. 13 replies.
Page 1 of 1 (14 items)
  • Mon, Mar 23 2009 11:21 PM
    • mikel
    • Joined on Wed, Oct 19 2005
    • Toronto
    • Posts 56
    • Points 670
    output 23.98psf to 59.94 with cross-convert?
    you know when you're sitting at home after a long day, and a potential problem pops into your head but you're nowhere near the system to test things out....?
    problem: I have a show at 1080p 23.98psf and I'll need to make two masters, one is 23.98 and one is 59.94 1080i. I know the cross-convert out of the Nitirs can play out 59.94 1080i from my project, but is there anything I need to know about the Digital Cut that is out of the ordinary? How do I properly generate 59.94 timecode on the HDcam SR deck? OR do I need to do a 'crash record' option on the Digital Cut tool? Will the Avid even let me sellect a 59.94 deck as an available machine to use?
    I'm confident that I can play the proper video out with the Nitirs cross-convert, but the idea of mastering a tape outside of my 'assemble edit' comfort zone scares me. Please tell me this is a common thing, that I just haven't had to do yet.
    thanks
  • Tue, Mar 24 2009 12:51 AM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Re: output 23.98psf to 59.94 with cross-convert?
    In the Digital Cut tool I have 1080i 59.94 as an output option in a 1080p 23.98psf project so you should be good.
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Tue, Mar 24 2009 1:17 AM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    Only on DX. Symphony NItris cannot do the frame cross convert.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Tue, Mar 24 2009 1:31 AM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    Burbank, Ca
    www.alphadogs.tv
  • Tue, Mar 24 2009 2:28 AM In reply to
    • mikel
    • Toronto
    • Posts 56
    • Points 670
    here's an idea (a time consuming one) that might work:
    play out my 23.98psf timeline to HDCam SR, then reload that SR though the machines format converter into a 59.94 project. Then after I cross my fingers and whisper silent prayers, see if my times actually line up and generate my new master in 59.94 from that new timeline. Yes it's a run around, but it could work.... maybe?
  • Tue, Mar 24 2009 3:39 AM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    mikel:
    That will work. Or, if you have an FCP system with a Kona card you can cut out one pass...
    Burbank, Ca
    www.alphadogs.tv
  • Fri, May 15 2009 4:21 AM In reply to
    • dharia
    • Joined on Fri, Sep 19 2008
    • Posts 187
    • Points 2,345
    Hey I want to do the same thing
    I have a nitris DX mac system
    I want to output to 59.94 HDCAM
    My 24p sequence has
    29.97 gfx  imported into the 24p project
    30i video imported files into the 24p project
    and then just 24p DVCPRO HD footage
    So if I do a cross convert layback will everytign look right or will the graphics look all studdery and whatnot?
    The other scenario is take al the gfx and 30i imports out  and do a quicktime reference of teh sequence then import to a 59.94 project reimport gfx and 30i clips and then cut them back in and lay back
    Any thoughts guys? Need to know within the next 5-6 hours.
  • Fri, May 15 2009 4:23 AM In reply to
    • dharia
    • Posts 187
    • Points 2,345
    by the way my sequence is a 24p sequence  at 720p HD  just to be clear
  • Fri, May 15 2009 4:38 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,670
    • Points 44,135
    Ok, here is my 2 cents:
    Since you say you have an SR deck, output the 1080p 23.976 master to SR, set the SR up to 1080i 59.94 and play to second SR deck.  Done.  No second SR deck?  Dig back to Symphony in new project and play back.
    Why not use the Symphony Nitris to convert?  It is not really designed to do so for production quality.  There have been issues with it keeping a proper cadence.  I would not trust it.  The SR deck will do the job perfectly.  You can totally control the cadence.
    Jef
    Jef Huey
  • Fri, May 15 2009 4:57 AM In reply to
    • dharia
    • Posts 187
    • Points 2,345
    I'm not using SR
    The deck I'm using is the HDW 500  Sony
    And I rent it so I get it for an hour to lay back and thats it so no testing time. (I know how to use it though)
    But yeh this sequence has to be ready to go out of my AVID when that deck arrives. So what do you suggest. Cross convert out of the Nitris DX  or  do the whole  export quictime ref, import to 59.94 cut in all gfx and stuff again whatnot
  • Fri, May 15 2009 7:20 PM In reply to
    • jef
    • Maryland
    • Posts 3,670
    • Points 44,135
    Sorrry I was responding to the original poster.
    Jef
    Jef Huey
  • Fri, May 15 2009 7:45 PM In reply to
    • mikel
    • Toronto
    • Posts 56
    • Points 670
    thanks Jef,
    that is exactly what I did. the one kink was that the format convert make the entire thing come in 1 frame late, but that's why we have 2-beeps right? Other than that, it worked perfectly.
  • Fri, May 15 2009 7:53 PM In reply to
    You can adjust the TC conversion of the 5500.
    It is in the TC Alt menu.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Sat, May 16 2009 9:34 AM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Studio City, CA
    • Posts 397
    • Points 4,465
    You need to set the time code sense menu to FC not Line then you won't be 1 frame off.  On the 5500 it is menu A10.  On the 500 decks there may not be this option it can be added with updated software and a board revision or swap.  I had a 500 that didn't have the option and was told it needed a new board to have the option.  Funny thing was the Sony engineer I spoke with had worked on the deck I was renting and he knew he had shipped the board to the previous owners of the deck but it apparently never got installed.
    mikel:
    thanks Jef,
    Symphony Nitris and Nitris DX 4.x and MCsoft 5.x & 5.5x, MCsoft 6, Artist Color [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
