Latest post Fri, Feb 27 2009 1:46 AM by Ervz Tia (Tikboy). 4 replies.
  • Wed, Feb 25 2009 8:20 AM
    m2t File Import Problem
    Hello,
    I'm importing a batch of m2t files I captured using Firestore & Sony Z1.
    99% went fine, but otheres, i get an error:
    "Exception: AudioElementaryStreamParserRep::Finish....nothing int he free queue..."
    Any ideas about this?
    Ervz Tia | Video Productions
  • Wed, Feb 25 2009 3:01 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,340
    • Points 29,170
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: m2t File Import Problem
    What version of the Media Composer are you using?
    The only frame rate that currently supported is 1080i/59.94. Could these have been recorded at a different frame rate?
    Can MPEG Streamclip open the files? You might be able to rewrap or transcode the files so they import.
  • Thu, Feb 26 2009 4:30 AM In reply to
    I used the same frame rate/format as the others that imported fine.
    Yes. I had to export it to QT using MPEG Streamclip but I also had to buy the $20 plug-in.
    Any ideas about that error? could it be a timecode glitch/skip?
    It's an MC 3.1.1
    Filed under: , ,
  • Thu, Feb 26 2009 1:33 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,340
    • Points 29,170
    If its the same frame rate and format, I have no idea what the issue could be. Could the clips be corrupt?
    As far as the plug-in; are you talking about the MPEG 2 playback option for OS X?
  • Fri, Feb 27 2009 1:46 AM In reply to
    That is correct.
    so i had to export the m2t files to huge QT files before i can import it to Avid.
    I just realized I have a tape backup that I could've simply captured! Geeked
    Oh well....digital/memory hype!
    (I shot HDV with a Z1 and FirestorePro)
