Latest post Wed, Feb 25 2009 9:20 PM by hbrock. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Feb 23 2009 8:17 PM
    • sofi725
    • Joined on Sun, Nov 23 2008
    • Posts 10
    • Points 120
    Moving Projects
    Hi everyone,
    I was wondering if there is a way to isolate all the Avid media that pertains to a specific project?  I want to move a project from one hard drive to another, but I don't want to have to copy over the media files from the other projects that I don't need.  Thanks!
    Sofi
  • Mon, Feb 23 2009 8:47 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 651
    • Points 8,100
    Re: Moving Projects
    i think "consolidate" is the thing your looking for. you could add a USB drive (with the avid media folder structure) select your sequence in the bin, right click (or was it in the hamburger menu?), select consolidate enter your handle length and use the USB drive as a target.
    HP xw8400 - 6GB RAM | W7 64 bit | MC 5.5.2 | Adrenaline with DNxcel Sony Vaio SB1Z1 - 6GB Ram | W7 64 bit | Blackmagic Design Ultra Studio SDI [view my complete system specs]
  • Mon, Feb 23 2009 9:28 PM In reply to
    • sofi725
    • Posts 10
    • Points 120
    Re: Moving Projects
    Thanks, this is a good suggestion, but I'd also like to know if there a way to move the entire media files in tact, for further editing onto another drive.  If anyone know how to do this, I'd appreciate some advice.
    Thanks!
    Sofi
  • Mon, Feb 23 2009 9:40 PM In reply to
    • Moses.M
    • Austria
    • Posts 651
    • Points 8,100
    Re: Moving Projects
    just select all clips of your project you want to move in the bin and then consolidate....
  • Mon, Feb 23 2009 9:43 PM In reply to
    • sofi725
    • Posts 10
    • Points 120
    Re: Moving Projects
    Ah, I see what you were saying now... Thanks!
  • Mon, Feb 23 2009 11:21 PM In reply to
    Re: Moving Projects
    Or use MDV ...
    http://fiool.nm.ru/progz/
    (wwld)
  • Tue, Feb 24 2009 3:14 AM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,460
    • Moderator: MCA Mac
    Re: Moving Projects
    Seconding MDV. I've used it for exactly this purpose a number of times. Works very well. Watch out if you've used any XDCAM EX material however as the 'Avid AAF' export technique creates clips with no project association, so they would be missed. Same goes for the older workflow with P2 where you'd drag MXF files directly from the P2 card to the Avid MediaFiles directory.
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Tue, Feb 24 2009 3:28 AM In reply to
    Re: Moving Projects
    Projects without a project association will be grouped by MDV into "Null Project".  You might be able to sort things out by Date & Time or other Metadata.
    (wwld)
  • Tue, Feb 24 2009 7:52 AM In reply to
    • Moses.M
    • Austria
    • Posts 651
    • Points 8,100
    Re: Moving Projects
    nice tool! didn't know that one... Geeked
  • Tue, Feb 24 2009 3:14 PM In reply to
    • sofi725
    • Posts 10
    • Points 120
    Re: Moving Projects
    Thanks everybody I'll definitely be checking out MDV
  • Wed, Feb 25 2009 8:53 AM In reply to
    • EREM
    • Paris, France
    • Posts 29
    • Points 280
    Re: Moving Projects
    Hy everybody !
    MDV seems a nice app but it seems also a PC app.
    Is there a Mac file on the page ?
    Mac OS X 10.4.4 Quicktime 7.0.4 Power Mac G5 2x2.7 Ghz 8 Go ddr SDRAM 5x500 Go and 4x1 To FireWire 800 hard drives on a seperate card Deck... [view my complete system specs]
  • Wed, Feb 25 2009 9:20 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,525
    • Points 64,140
      Moderator: MCA Mac
    Re: Moving Projects
    Try MacMedia Sift.  Don't panic when all of your media shows up offline after the sift.  The program puts media files into folders based on the Project Name.  You need to pull the media out of the folder for the Avid to see it in the MediaFiles folder.
