Latest post Fri, Mar 20 2009 4:15 PM by Abeyta. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jan 27 2009 11:30 AM
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 504
    • Points 6,080
    1:1 MXF erratic in version 3.1.1
    BUG ALERT?
    Strange one here, but since I upgraded to version 3.1.1 last week, I've been unable to render keys or titles or even reformat fx over material created at 1:1 MXF.
    Example, I need to render a title over some 1:1 digitized material (for one reason of another), but once rendered, the title vanishes (the effect icon's still there).  The same happens when I reformat 4:3 to 16:9, the effect gets cancelled out.
    This is not normally an issue, because these are real time effects, but on occasion, they do need rendering.
    The kick is though, there is no problem rendering these effects over media created at 1:1 10b MXF!!! or any other resolution.  It's just 1:1 MXF.  Also, I've tried this in PAL and NTSC progressive and interlaced with same results.
    There's also no issue with the title media being 1:1, just the media it's placed over. I can't even do a video mixdown.
    Guess i'll be working in 10 bit for a while.
    Media Composer 2019.8.0 Dell Precision 5820, 32GB, i9-9920x, Quadro P2000, W10 [view my complete system specs]
    @jaketheeditor
  • Thu, Feb 5 2009 9:31 PM In reply to
    • MikeAmmo
    • Posts 6
    • Points 80
    Re: 1:1 MXF erratic in version 3.1.1
    Along the same lines:
    Symph Nitris 3.1.1
    Can digitize every SD / HD resolution except SD 1:1 which results in this error:
    Exception: PMM_MISMATCH_VIDEO_ENCODING
  • Fri, Feb 6 2009 3:01 PM In reply to
    • Conformers
    • Posts 9
    • Points 145
    Having exact same issue. What cpu are u using and is it nitris hardware or dx?
  • Fri, Feb 6 2009 4:09 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,666
    • Points 44,105
    Same problem.  Cannot dig 1:1 (8 bit) MXF SD NTSC with a Symphony Nitris ver 3.1.1.
    We can dig 1:1 x (10bit).
    Jef
    Jef Huey
  • Fri, Feb 6 2009 4:17 PM In reply to
    • jakeheat
    • Posts 504
    • Points 6,080
    You can see my system specs below Conformer.
    I have found that if you dump all your site settings and mcstate settings,  this buys you some time before the bug returns.  Not so much a fix, more an annoying temporary workaround.
    Other than that my Symphony is great... except when I'm trying to online. (?)
    @jaketheeditor
  • Fri, Feb 6 2009 5:06 PM In reply to
    • curtisn
    • Irving, TX
    • Posts 27
    • Points 285
    Tech Support confirmed that 1:1 MXF 8-bit codec is broken in 3.1.1.  Use 10-bit.
    MC 8.5, HP Z840, NitrisDX [view my complete system specs]
  • Fri, Feb 6 2009 5:12 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    v3.05 captures 1:1 8bit on Nitris DX just fine.
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Thu, Mar 19 2009 8:15 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Has anyone tried to capture MXF 8 bit in 3.1.2 or 3.5? Is this working again now?
  • Fri, Mar 20 2009 4:15 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    I just captured 1:1 mxf 8 bit on v3.5 without error.
    Phoenix, Arizona
