Latest post Sun, Sep 13 2009 11:36 AM by sonnydj2003. 4 replies.
  • Thu, Jan 1 2009 1:04 AM
    • Adrian25
    • Joined on Thu, Jan 1 2009
    • Posts 2
    • Points 40
    Colors don't display correctly on playback
    So I'm running Avid MC 3 on a Macbook - 2.4Ghz, 4GB Ram, with a Panasonic mini DV camera.
    After I capture my clips, or during playback of the clips from the DV camera into Avid, the colors do not display correctly in the Record Monitor.  IT seems like there is a lot of green and a lot of Purple.
    I'm running the same system on a iMac G5 with a 1G of Ram and slower processor, with the same exact settings as for the macbook, and it is working perfectly.
    Although those colors in the Record monitor on the macbook don't display correctly either during playback from DV device, or after the clip has been captured in the bin, the Client monitor will display the correct colors if attached to the DV device.
    PLEASE HELP.
    I tried everything.  Could it be the video card, graphics of the macbook?  It plays imported clips correctly and it looks pretty good graphically.  Also when the scene is stopped the colors go back to normal.  As soon as I click play the coloring becomes dominated by green and purple.
    Anybody?
    Cheers!
  • Fri, Jan 2 2009 12:05 AM In reply to
    Re: Colors don't display correctly on playback
    Sorry Adrian, but MC 3 is only qualified for MacBook Pro - it must run on Leopard.
  • Fri, Jan 2 2009 3:35 AM In reply to
    • Adrian25
    • Posts 2
    • Points 40
    I have a macbook, not a macbook pro, but I am running Leopard.  The software works.... I just can't see the colors correctly.  All other functions work perfectly, and I can also see it correctly in the Ciient monitor.
    No hopes?
  • Fri, Jan 2 2009 6:33 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 441
    • Points 5,105
      Avid Certified User
    That sounds like an integrated graphics issue so I doubt there's anything you can do.
    If your external monitor is displaying correctly at least your footage is theoretically unaffected.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Sun, Sep 13 2009 11:36 AM In reply to
    i have the same problem on my macbook white, but when i tried it on windows os using bootcamp on same macbook, i did not experience the green playback, everything is perfectly normal. one other thing, surpricingly, mc 3 works perfectly on my old macmini, imagine it is the first gen macmini, almost 5 year old macmini, i just upgraded it to leopard ang put a max ram of 2g. never let me down on any of my projects. it must be in the model of the video card.
