Latest post Wed, Dec 10 2008 8:29 PM by Abeyta. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • Mon, Dec 8 2008 10:21 AM In reply to
    Re: Please Help! HD Monitoring....?
    Is the 24psf rate just for film work though? I will be delivering to BBC at 1080/50i which is all they take (even if shot 1080/25p).
    Plasmas sound good, are they just fed from nitirs hdmi?
  • Mon, Dec 8 2008 9:26 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 504
    • Points 6,080
    We have two JVC DTV-24L1U's.
    Absolutely fantastic.  They take a couple of minutes to warm up in the morning, but other than that I can't fault them for anything, especially colour reproduction. We use them for SD, HD, 25p 25i 24p - all good.  The majority of work here we do are commercials so I can safely say that they're more than suitable for broadcast.  They're not too bright, which makes them ideal in a dark online suite. But if you are doing HD make sure that you have a decent compatible waveform monitor/ vectorscope - this will cost a fair bit more than the video monitor - but any tech errors with HD masters will also be costly.
    One thing to be careful of when using LCDs, is that you have to look at them straight on - or thereabouts, otherwise the image will appear milky.  So make sure you client is sitting dead on when they view you work.
    Media Composer 2019.8.0 Dell Precision 5820, 32GB, i9-9920x, Quadro P2000, W10 [view my complete system specs]
    @jaketheeditor
  • Mon, Dec 8 2008 11:42 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,994
    • Points 37,755
    jakeheat:
    ...through the back of your head...
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Wed, Dec 10 2008 6:31 PM In reply to
    The Kuro shows everything the Avid spits out... both over HDMI and component...
  • Wed, Dec 10 2008 8:29 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    For HD I use both, a Panasonic BT-LH 2600W and an Elite Kuro Pro 150 60" plasma. The blacks on the Kuro are much truer. I also use a Sony PVM via sdi for the downconvert.
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
