Latest post Sun, Feb 5 2012 9:35 PM by chuckkahn. 7 replies.
  • Tue, Nov 25 2008 4:50 PM
    • chuckkahn
    • Toronto
    • Posts 366
    • Points 4,030
    Sound TC in bin but doesn't come up in EDL Manager
    I've seen this problem for years -- have you?
    Sound TC is 19:58:08:28 in the bin, but it comes up as 00:00:00:00 in EDL Manager
    Link to image: http://farm4.static.flickr.com/3184/3059324474_fc56d09720_o.jpg
    Sound TC is 19:58:08:28 in the bin, but it comes up as 00:00:00:00 in EDL Manager.
    Avid Media Composer 2018.11 / MacOS High Sierra / iMac (Retina 5K, 27-inch, 2017) / 4.2 GHz Intel Core i7 / 64 GB 2400 MHz DDR4 [view my complete system specs]
    Filed under: ,
  • Fri, Jul 17 2009 1:43 AM In reply to
    • chuckkahn
    • Toronto
    • Posts 366
    • Points 4,030
    Re: Sound TC in bin but doesn't come up in EDL Manager
    I'm seeing it now where the Sound timecode is on A1 but not on A2 of the same clips
    I've posted a video on YouTube showing A2 disappearing when scrolling between two clips on the timeline
    http://www.youtube.com/watch?v=_KBC4oh9gN8
  • Fri, Jul 17 2009 11:49 PM In reply to
    • swatchpost
    • Joined on Fri, Apr 4 2008
    • Los Angeles, CA
    • Posts 96
    • Points 1,165
    I had this problem recently after I had turned over my audio EDLs to sound editorial.  It seemed the problem stemmed from certain shots that weren't synced during Telecine and we had to sync them in the Avid.  Essentially, the metadata wasn't showing up in the EDL because it was referencing the subclips I made from the AutoSync of the imported production audio and the captured dailies.  The EDL was showing zeros because it was referencing the ORIGINAL master clips, that had no audio data, thus the zeros, and not the subclips that actually had the correct metadata.
    What I ended up doing was creating a new sequence with just the shots that were creating the zeros in the EDL, and exported an OMF 2.0 using the "Linked to" setting.  A folder was created that had the audio files with the metadata and sound editorial got their metadata from those shots that way.
    Hope this helps any at all.
    Cheers,
    Yusef
    MC v5.5.3, 2x2.93GHz 8Core Mac Pro, 32GB RAM, 10.7.5, QT v7.6.3 ; Avid MC v5.5.3, 2x3.06GHz MacBook Pro, 8GB RAM, 10.7.5, QT v7.6.3 [view my complete system specs]
  • Fri, Jan 7 2011 12:17 AM In reply to
    i am having this exact same problem although it only seems to be happening with clips in A2 on the EDL. however none of these shots were synced in the avid. any thoughts on this? i am on MC v5.0.3.5
    thanks in advance. hope everyone is well
  • Mon, Feb 14 2011 5:51 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 366
    • Points 4,030
    Exit Avid, search and delete all MCState files, and restart Avid.   Since regularly doing this my A2 EDL problem has diminished.
  • Mon, Feb 14 2011 6:04 PM In reply to
    • Eric Hill
    • Joined on Fri, Feb 4 2011
    • Portland, OR
    • Posts 141
    • Points 1,600
    I was having the same problem on a feature cut on 3.5.13 and this was the only workaround I was able to find. Total PIA but it worked.
    Select the sound TC of the master clip in the bin, command x to cut, tab out of the sound TC field then back in,   command v to paste.  Save and re-export the EDL.
    Here's a Youtube video of the process:
    http://www.youtube.com/watch?v=mRji9PJXWxE
    MC 8.4.0, OS X 10.9.5, mid-2010 MacPro, 2x2.66 GHz, 32GB RAM, NVIDIA GeForce GTX 680, AJA IO Express, Editshare (build 6.4.0.6-0) [view my complete system specs]
  • Thu, Sep 8 2011 9:54 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 366
    • Points 4,030
    Hey, I posted that video!
    Version 5.5.3 is not immune to this bug.  Anyone found a better solution?   Or a column that will reveal which clips have this problem?  This is screwing up my EDL.
  • Sun, Feb 5 2012 9:35 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 366
    • Points 4,030
    Happening in 5.5.1 for Windows in a different 23.98 1080p project.   This time with sound files imported separately and synced to tapeless (RED) picture.  (Previously experienced with two channel audio digitized with picture from DV tape and Sound TC coming from imported ALE file.)   A1 will have timecode, but A2, A3, etc do not.   Cut and paste from Sound TC column fixes it (fills in the TC on the empty tracks) but it is a tedious fix.   Annoying.
