Latest post Mon, Nov 24 2008 11:23 AM by luca.mg. 3 replies.
  • Fri, Nov 21 2008 4:56 AM
    • thacha
    • Posts 10
    • Points 160
    Problem when capturing from Canon XLHI 50 Camera
    Hi, I'm using MC 2.8 with Mojo SDI on HP XW8600. And when I capture from Canon XLHI 50 camera sometimes I get an error message
    Exception: ADM_DIO_ERROR_OCCURRED, DIOerr:PMDIOParserHelper:: Parse - error occurred in parser ParserOutputGOPBufferRep::CalculateTimecodeFromGOPTimecode - timecode of last gop's timecode is reserved\devices\digitalio\Pyromaniac\PMPIO Tester\MPEGPerser\PerserOutputGOPBuffer.cpp
    And then I will lose connection with the camera and have to reset it again in Deck Configuration.
    Please help. Thanks.
  • Fri, Nov 21 2008 8:51 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    Re: Problem when capturing from Canon XLHI 50 Camera
    I have had problems capturing from this camera as well, here's what I've found out: You have to set the camera output mode before connecting it to the computer, if You happen to switch it off You'll have to set it again as at power up it goes to a default configuration that may not match Your Avid project; once in Avid You have to manually select the proper deck configuration. I hope this helps.
    Symphony 20.04, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Mon, Nov 24 2008 12:35 AM In reply to
    • thacha
    • Posts 10
    • Points 160
    We did that. But the thing is it lost the connection to the camera during capturing. I tried to find if there's any limitation working with this camera. But can't find anything useful on the Knowledge Base.
    But thanks anyway.  Smile
  • Mon, Nov 24 2008 11:23 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    I got it working on MC 3.0.5 and I notice You're on 2.8.
    peace luca
