Latest post Wed, Dec 3 2008 10:57 PM by jwrl. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Nov 4 2008 11:09 AM
    • aszasz
    • Joined on Tue, Nov 4 2008
    • Warsaw
    • Posts 6
    • Points 80
    DNA detected hardware underrun error
    Hi
    That's the problem: during digital cut for BetaCam SP or DVCam it appears. Hardware underrun error.
    I've read all the posts from the past here. And tried suggestions. Nothing, it's the same all the time.
    I've made new project, I've cleaned MCSite and User Settings, I've disabled audio card (in BIOS), I've changed video res. on monitor to 16bites, I've moved firewire card to 2nd slot. NOthing. After few seconds or f.ex. 15 minutes error appears.
    I was thinking about uptading system to xw8400 or something like that but I've found here that people with this workstation have this problem also.
    Waiting for responses
    MC 2.8.4, Mojo (analog), Pentium P4 2.8GHz, Biostar Mainboard P4M900-M4, 2 x 1GB 533MHz DDR2 SDRAM, GeForce 7600GT (PCI-Ex16), Texas Instr. Firewire -... [view my complete system specs]
    Filed under: , ,
  • Tue, Nov 4 2008 11:13 AM In reply to
    Re: DNA detected hardware underrun error
    what is on your timeline (resolution?) can you give more details on your specs... hardware and software? What kind of disks? How are those connected?
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Tue, Nov 4 2008 11:21 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,411
    • Points 97,300
    How are your media drives connected?  Hardware underruns are most commonly due to drive speed issues.
  • Tue, Nov 4 2008 12:15 PM In reply to
    • aszasz
    • Warsaw
    • Posts 6
    • Points 80
    timeline is set in best resolution
    There are two harddiscs in IDE slot and two other in SATA. I need to check out how speed they are.
  • Tue, Nov 4 2008 1:44 PM In reply to
     ok. what happens when you set tl quality to yellow/green. Disks should have 7200 rps minimum.
  • Tue, Nov 4 2008 2:16 PM In reply to
    • aszasz
    • Warsaw
    • Posts 6
    • Points 80
    thanks, i will check it out tomorrow 'cause i dont have it at home.
    So, when its set to yellow/green discs should have speed at least 7200, is that right? What about whole green?
  • Tue, Nov 4 2008 11:03 PM In reply to
    no, the speed should always be 7200 rps min.
    Whole green means a lot of data ... green yellow is less data. So your disk or bus might not be able to keep up.
  • Mon, Nov 17 2008 2:25 AM In reply to
    • aszasz
    • Warsaw
    • Posts 6
    • Points 80
    OK
    I have checked the disks: All have 7200rpm - see details of my hardware - I have updated it.
    When the "quality button" is yellow/green and I make digital cut -> the button automatically turns to green and the recording is beginning. And the error appears
    I made the mixdowns (video and audio) and have put it to one drive (and then to another) - during the digital cut still error appears.
    Maybe these BIOS settings will tell something:
    SATA Controller Mode : IDE    (the second option to choose is "RAID")
    VIA OnChip PCI Device:   soundcard: disabled
                                        LAN Controller : enabled
                                        LAN Boot ROM : disabled
    ONBoard VGE Ap. Size : 128M (there's option: 256M)
    VGA Share Memory Size : 128M (also there's an option: 256M)
    Finally I have set in Digital Cut "RT DV25" (instead of RT DNA) - and I managed to record over 20 minutes without errors to tape. So far, so good - but its good only for DVCams. For putting to BetaCam tapes its lowering the quality.
    Do you have any suggestions how to make digital cut with RT DNA with no DIO hardware underrun errors?
  • Tue, Nov 18 2008 5:31 PM In reply to
    • aszasz
    • Warsaw
    • Posts 6
    • Points 80
    Hardware Underrun Error during the Digital Cut
    Hi, I was previously foruming with this problem but finally got no suggestions...
    So I decided to write it one more time...
    I have checked the disks: All have 7200rpm - see details of my hardware.
  • Tue, Nov 18 2008 9:31 PM In reply to
    • jwrl
    • Posts 8,411
    • Points 97,300
    Re: Hardware Underrun Error during the Digital Cut
    If you're using a PCI-e display card you don't need your on-board display active at all.  Your on-board VGA should be disabled, and the aperture and share memory settings shouldn't be able to be set.  With the on-board VGA active you will have conflicts.
  • Wed, Dec 3 2008 7:02 PM In reply to
    • aszasz
    • Warsaw
    • Posts 6
    • Points 80
    Hi
    I set up VGA Share Memory Size to disabled in BIOS and everything seems to be ok. So, we'll see in the future.
    Thank you jwrl for helping!!!
  • Wed, Dec 3 2008 10:57 PM In reply to
    • jwrl
    • Posts 8,411
    • Points 97,300
    Glad it helped.
