Latest post Sat, Jun 27 2009 3:42 AM by Kenton.VanNatten. 15 replies.
  • Wed, Oct 22 2008 5:52 PM
    Mojo SDI and timecode
    Hi
    I have been using MC 3.00 on my mac book pro and mac pro. I have ingested all kinds of footage, DV, HDV etc. Recently I got asked to offline a DigiBeta project so I bought an SDI mojo secondhand and hired a Sony J30. Having been converted from Final Cut to avid within the last year I was absolutely shocked to find that the mojo has no deck control. Unbelievable. So then I worried about timecode and how exactly I was going to get the tape timecode into my Avid. I have searched far and wide and so far have not found a decent answer to the following question. How do I capture SDI video with timecode using a mojo SDI? I need exact steps here, do I need some other piece of tech or is it simply a configuration issue. Somebody please help.
    Mac Pro Quad 2.66, OSX 10.5.5, 5 gig RAM, a sick graphics card 15" Mac Book Pro Core 2 Duo 2.5, OSX 10.5.5, 4gig of RAM, a graphics card AVID MC 3... [view my complete system specs]
    Filed under: , ,
  • Wed, Oct 22 2008 6:40 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: Mojo SDI and timecode
    Deck control is a simple matter of a keyspan USB to serial adapter.
  • Wed, Oct 22 2008 6:49 PM In reply to
    Yes
    Thanks very much for the tip, but how does avid know when you have this connected? Is there any option I have to click?
  • Wed, Oct 22 2008 7:06 PM In reply to
    phoenixofedair:
    Avid will see it as a serial port thus allowing you to use it in the Deck Configuration window as a Direct channel.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Thu, Nov 6 2008 12:46 AM In reply to
    I too am curious about this. Will the AVID MC detect the timecode on SDI feed via the Mojo SDI?
    MacBook Pro 2.5 Ghz Intel Core 2 Duo, 4 Gig of Ram, Mac OS 10.6.8, Media Composer 5.5.2 [view my complete system specs]
  • Thu, Nov 6 2008 12:50 AM In reply to
    JonathanCrandall:
    No.
  • Thu, Nov 6 2008 12:52 AM In reply to
    • janusz
    • Paris
    • Posts 396
    • Points 4,650
    No, timecode comes in through the RS422 link (via the keyspan adapter) if you are capturing from SDI, or through firewire if you are capturing via firewire.  The VITC is not used as the timecode reference.
    Janusz
    MC 2018.12 / OS 10.12.6 + others elsewhere [view my complete system specs]
  • Fri, Jun 26 2009 2:43 AM In reply to
    I just rented a J-30 for some offline capturing of BetaSP - though I'm using the S-video and RCA audio into my Analog Mojo.  (I'll upres later using NitrisDX and SDI or Component).
    I believe I have everything set up correctly, except I have no Deck Control.  I have the Keyspan USA28xB and my Mac and my Avid see it.  I can go into Deck Config and choose Direct on USA28x... as the Channel, but Auto-Config (or manual config) does nothing - No Deck.
    The Keyspan is connected directly into the 9-Pin 422 on the J-30 and according to the Qualified Device Guide - that is correct (says:  "Must use RS-422 direct control").
    Any help?
  • Fri, Jun 26 2009 10:25 AM In reply to
    • St.John
    • UK
    • Posts 267
    • Points 3,305
    Kenton
    From what I remember about the J30, it needs special software to be operated remotely (JZ-1) section 4-4 of the manual; check with your rental company.
    If it has been loaded, then perhaps the remote is set to firewire control, and not rs 4.2.2, but I'm not sure how to check this
    Hope this helps
    St.John
    Mac Pro trashcan 3.5ghz 6 core 32 gb Ram Media composer 10.19.12 AJA io4k [view my complete system specs]
  • Fri, Jun 26 2009 2:31 PM In reply to
    • swatchpost
    • Joined on Fri, Apr 4 2008
    • Los Angeles, CA
    • Posts 96
    • Points 1,165
    Wow.  I wish I had known about the TrippLite USB > serial adapter back when we were capturing on the project I'm currently working on.  It always made me really nervous to be on a film project and dealing with timecode over firewire.  I have a Mojo DX now with an RS422 port so it doesn't really apply any more, but that little adapter is a great think to know about.
    Once again, thanks BLKDOG :o)
    MC v5.5.3, 2x2.93GHz 8Core Mac Pro, 32GB RAM, 10.7.5, QT v7.6.3 ; Avid MC v5.5.3, 2x3.06GHz MacBook Pro, 8GB RAM, 10.7.5, QT v7.6.3 [view my complete system specs]
  • Fri, Jun 26 2009 2:46 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    That was actually Kenton
  • Fri, Jun 26 2009 2:56 PM In reply to
    Hey Swatchpost, does the RS422 on the Mojo DX actually work? I've been looking for someone to give me a definante answer on that.
  • Fri, Jun 26 2009 3:13 PM In reply to
    • swatchpost
    • Los Angeles, CA
    • Posts 96
    • Points 1,165
    Yes, absolutely.  I've captured from a SONY DSR-1500 SDI as well as your generic D-BETA deck SDI as well using the RS422 deck control both times.  Works exactly like any other Avid BOB.  Have you heard differently?
  • Fri, Jun 26 2009 3:22 PM In reply to
    I just know that when the DX was first advertised, they were saying the serial port was for service use. But it's good to know that it works for deck control/timecode. Thanks
  • Fri, Jun 26 2009 4:43 PM In reply to
    St.John:
    Interesting, I scoured the manual last night, but didn't see anything about a software for remote operation.  There was a whole section devoted to using the Remote "Commander" (ie, remote control)
    I was looking for some kind of flip switch to enable 422 remote, but didn't see that either.  The rental house has given me two more Keyspans and another 422 cable to try out - thinking that maybe I have a faulty one.
    I'll look into the software thing though.
    Thanks!
