Latest post Tue, Mar 29 2011 8:31 AM by camoscato. 11 replies.
Page 1 of 1 (12 items)
  • Sun, Sep 28 2008 6:35 AM
    Free DV Authorization & Serial Codes?
    Locked Contact
     well i recently downloaded the free version but there is no numbers for authentication or serial code.....can someone give me them or tell me where to get one...? please
  • Sun, Sep 28 2008 6:38 AM In reply to
    Re: Avid free DV doesn't work at all
    Locked Contact
    Where did you download it from?  The product has been EOL (End if LIfe) for a very long time.  Avid no longer provides the download, or the authorizaion codes.
    (wwld)
  • Mon, Sep 29 2008 12:38 AM In reply to
    Locked Contact
     i dont remember but i downloaded it and it has no codes or anything.....can u give me some or tell me where to get a keygen..thanks
  • Mon, Sep 29 2008 12:40 AM In reply to
    Locked Contact
  • Tue, Sep 30 2008 8:19 AM In reply to
    Locked Contact
    scootas4life:
    It doesn't have any codes or anything because it's no longer an Avid product, and no, nobody is going to tell you where to get a keygen.  Most people here use Avid software & hardware to make  a living, so if I were you I'd stop asking for hacks to get Free DV to work.
    good luck,
    Carl
  • Fri, Oct 3 2008 2:44 PM In reply to
    Locked Contact
     I was about to reload my copy of Avid Free DV (I have found my serial number and authorisation code) but got the message to the effect "not supported on this operating system".  I am running Vista 64 bit.  Is it Vista or 64 bit which it does not want to play with?
    I never actually used FreeDV when I had it loaded on my previous PC.  How different is it from Media Composer?
    Actually, I have never used either and wanted to have a quick evaluation. I gather that AVID is difficult to learn unless you learn it properly.  Would you suggest trying one of these two AVID products or going for an inexpensive consumer product like Pinnacle which may be easier?  I want to be able to edit different formats which I might download from the web including flv files and preferably switch between formats.
    Grateful for any advice.
  • Fri, Oct 3 2008 2:51 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Locked Contact
     Yes it's Vista. Free DV was never developed for Vista and is EOL. If you are a student, you can get Avid MC soft for $295. It doesn't get better than that.
  • Fri, Oct 3 2008 4:05 PM In reply to
    Locked Contact
    Hugh Meares:
    Like BLKDOG said, it's Vista.
    Hugh Meares:
    It's very similar to Media Composer; it just doesn't have a lot of the capability Media Composer has.
    Hugh Meares:
    I didn't find Avid tough to learn, but I came from a linear editing background and the paradigms are similar.
    Hugh Meares:
    If this is for your own hobby, then I'd say get something smaller and easier.  If you're going to be working to make money, I'd get Media Composer.  Using stuff from the web will be a bit of a trial, but once you get the hang of it it's not that bad.
    good luck,
    Carl
  • Mon, Oct 27 2008 5:30 AM In reply to
    • allscots23
    • Joined on Mon, Oct 27 2008
    • Posts 1
    • Points 15
    Locked Contact
     Would you be able to give me the serial number and authorisation code.  I have had to reload mine and with the product no longer available I can't reinstall it.
    Many thanks ... Alan
  • Mon, Oct 27 2008 7:29 AM In reply to
    Locked Contact
    Hi Alan,
    As was said earlier in this thread, there is no way to get a serial number or authorization code, because FreeDV has been end of life for over a year.  I'm sorry I don't have better news.
    good luck,
    Carl
  • Tue, Nov 4 2008 3:06 PM In reply to
    • Atomike
    • Nebraska
    • Posts 726
    • Points 11,055
    Locked Contact
    Actually, FreeDV does work with Vista. You need to change the install .exe to be in XP compatibility mode. Then once installed, run it in XP compatibility mode.
    As far as the key goes - you'll have to get one from somebody who got one, but doesn't want it anymore. There may be millions of keys out there going unused - if you can get a legal one, there's no reason in the world you couldn't use it.
    Media Composer version: usually newest release, or 1 behind. Nvidia GTX 1070Ti Windows 10, Core i7 8700K processor, ASRock GA 1151 Z370 Motherboard... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Tue, Mar 29 2011 8:31 AM In reply to
    Locked Contact
    Thread locked because it's attracting spammers, and there won't ever be any more Free DV codes.
    ciao,
    Carl
