Latest post Sun, Sep 28 2008 1:16 AM by Larry Rubin. 11 replies.
Page 1 of 1 (12 items)
  • Sat, Sep 27 2008 4:02 PM
    Match frame
    I am very fond of the match frame feature.
    For some reason with MC 3 (PC, no hardware, dual core, 4GB RAM) I get a message box ordering me to mount a tape. Is there something here that I am overlooking? I just want to locate a frame in the original footage...
  • Sat, Sep 27 2008 4:12 PM In reply to
    Re: Match frame
    How are you invoking the Match Frame?  Keyboard or clicking the icon?
  • Sat, Sep 27 2008 4:39 PM In reply to
    Re: Match frame
     That's very strange, because the dialog box you're referring to is part of the batch capture process, not the match frame function. Match framing should not bring up any additional dialog. It might be time to rebuild the site settings files.
  • Sat, Sep 27 2008 7:09 PM In reply to
    Re: Match frame
     Oh I got the problem. There are now two additional match frame icons that do other hings. Managed to locate the original one :)
  • Sat, Sep 27 2008 7:16 PM In reply to
    Re: Match frame
     The frame icon that is black character on a light field is "match frame"
    The frame icon that is white character on a dark field is "reverse match frame"
    I know of no other match frame icons. Have you found a third one?
  • Sat, Sep 27 2008 7:56 PM In reply to
    Re: Match frame
    Yes, please post a screen shot of this "new" match frame icon
  • Sun, Sep 28 2008 12:21 AM In reply to
    • ctrl+z
    • Joined on Sat, Jul 14 2007
    • Posts 20
    • Points 250
    Re: Match frame
    Isn't that "Find Frame"?
    Command Palette > Other
    Icon looks like a small video monitor. Function implemented in MC at least two years ago. Very useful.
    MC7, mojo DX, xw8600, 24GB RAM, quadro FX3700, 12TB LSI raid 6, Win 7 [view my complete system specs]
  • Sun, Sep 28 2008 12:27 AM In reply to
    Re: Match frame
     Not at my Avid right now so I can't confirm. How does it differ in function from match frame? Or reverse match frame?
  • Sun, Sep 28 2008 12:31 AM In reply to
    • ctrl+z
    • Posts 20
    • Points 250
    Re: Match frame
    Larry Rubin:
    Locates frame under the cursor directly on source tape without the need for manually typing TC in capture window.
  • Sun, Sep 28 2008 12:39 AM In reply to
    Re: Match frame
    ctrl+z:
    Locates frame under the cursor...
    What frame are you referring to? It sounds like this is a function tied to the capture tool.
  • Sun, Sep 28 2008 12:56 AM In reply to
    • ctrl+z
    • Posts 20
    • Points 250
    Re: Match frame
    Larry Rubin:
    Not necessarily. You park the cursor on the desired frame, press Find Frame button - then system prompts you for inserting required tape and cues the deck. Invoking capture tool is optional but still necessary for capturing anything.
    btw. sorry for my English Smile
  • Sun, Sep 28 2008 1:16 AM In reply to
    Re: Match frame
     OK, I can see where that would be handy if you had to quickly re-capture a clip over again at a later time, which can also be done with the batch capture function. Can't see much of any other use for it, though.
