Latest post Thu, Sep 18 2008 2:35 AM by dione. 4 replies.
  • Tue, Sep 16 2008 7:58 AM
    • dione
    • Joined on Tue, Sep 16 2008
    • Posts 2
    • Points 30
    Help - error trying to export AAFs
    We are trying to export an AAF file in MC 3.0 and having no luck - we're working in a 23.98 project with PCM audio, and have tried all sorts of trouble shooting.
    We keep getting the error message
     "Assertion failed: strlen(urlPath) < sizeof(PathName_t)
    File: /Snapshots/releng.relengintel1_1214631138/vobs/coresw/
    ame/Projects/Mac/../../src/ameOMFI/AURLLocator.c, Line: 458"
    And then avid generally crashes.
    We've tried the same things as this guy:
    http://archives.bengrosser.com/avid/2008-07/msg00775.htm
    But we are unable to use the same solution as him (of converting to AIFF and exporting as an OMFI file) because we cant get transcode to work at all on any of the clips.  More errors and system crashes every time.
    Any ideas would be greatly appreciated!!
  • Tue, Sep 16 2008 12:31 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: Help - error trying to export AAFs
    Sounds to me like you are hitting some bad media (Probably an effect). Try exporting a small portion of the sequence. If you can get that to go, then export larger chunks until you can find the problem portion of the sequence.
  • Tue, Sep 16 2008 11:51 PM In reply to
    • mc_guyvr
    • New Zealand
    • Posts 1
    • Points 15
    We are seeing this exact problem - 23.796 project, 24bit PCM audio setting, MC 3.0, MojoDX.
    We have also tried most of the troubleshooting on this post:
    Have you found any solution?
    Regards
    Matt
  • Wed, Sep 17 2008 12:29 PM In reply to
    • boltown
    • buenos aires
    • Posts 230
    • Points 2,825
    Check if there's any special character in tape name or if it's name is longer than 8. I had a simmilar problem and solved it modifying tape names of clips.
    Hope this helps
    Intel 755xbx2 mobo Core 2 duo 2.2GHz 4GB RAM Quadro fx550 Graphic board Pyro DV Firewire board [view my complete system specs]
    www.wancamp.com.ar
  • Thu, Sep 18 2008 2:35 AM In reply to
    • dione
    • Posts 2
    • Points 30
    Hi all,
    thanks for the advice. We had previously tried exporting small parts of the sequence and it seemed to be imported audio that would always stop the aaf from working - i.e. all of our temp music and sfx.
    The problem is sorted for now though - interestingly we were able to export the aaf on a PC first try (but the problem still exists on our macs)
    Thanks again and I'll keep at it and update if I get any results.
