Latest post Wed, Sep 17 2008 6:53 PM by Kay Anderson. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Sep 4 2008 12:10 AM
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
    font looks good in Boris - jagged in host
     I've posted this at the Creative Cow site, too...
    Still using Avid Xpress DV 3.5.  Also use Boris Red 3.04 as a plug-in.
    The font looks great in Boris but after I "apply" it to the host, then render it, it doesn't look "vectored."  It looks jagged.
    Kay
    Dell Precision 340 Workstation Win XP Pent 4, 1.80 Ghz 512 MB ram ACPI Uniprocessor PC Disk drives: IC35l120 avva07-0 SCSI (x2) Prolific PL3507... [view my complete system specs]
  • Thu, Sep 4 2008 9:16 PM In reply to
    • Posts 10,736
    • Points 224,820
    Re: font looks good in Boris - jagged in host
    axel andy
    I checked with the Boris specialist at Avid and he says that when Red is used as a plug in, the render happens in the Avid editor and not in Red. I think it's related to the yellow/gren settings as in you may be rendering in draft mode.    Can you check that please.
  • Thu, Sep 4 2008 9:23 PM In reply to
    Or a simple DV codec compression degredation?
  • Fri, Sep 5 2008 2:48 AM In reply to
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
    Marianna -
    You're right that the host application, in this case, Avid, does the rendering.  I don't know what you mean by the "yellow/green" settings...
    K
  • Fri, Sep 5 2008 2:49 AM In reply to
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
     How do I check about a codec degredation?
    K
  • Sat, Sep 6 2008 4:03 PM In reply to
    • Posts 10,736
    • Points 224,820
    That determines what setting you are on.... donttrying rendering in Draft and see if that changes the jaggies.
    marianna
  • Sun, Sep 7 2008 2:58 PM In reply to
    • papu
    • Joined on Wed, Sep 3 2008
    • india
    • Posts 40
    • Points 405
     Boris red pugins frame rate you have to cheak if its lower than the avid that looks jagged .
    Intel(R) Pentium(r) 3..40GHz. DDR2 ram 2Gb. 1TB of internel Hardisk. Xpress HD. Nvidia Graphic card. [view my complete system specs]
  • Sun, Sep 7 2008 7:58 PM In reply to
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
     Could you be more specific.  Are you saying "don't" render in draft?  Are you talking about while I'm in Boris?  Boris allows you to view your timeline in a number of settings.  Just before I "apply" the setting to Avid I can either "preview to ram" or "preview to ram at half rate" or "preview to ram at quarter rate."  I've tried each of these previews before "applying" to avid and it makes no difference.  According to the Boris manual, when you're working from the host ap, the draft or (higher quality) settings make no difference when you finally render in Avid.  Is there something else I'm missing...
    Finally - Is it possible that a different mouse could affect fonts in Avid?
    K
  • Mon, Sep 8 2008 4:32 PM In reply to
    • papu
    • india
    • Posts 40
    • Points 405
     no i am telling that the softwere u r using it's maximem sige of video format lite :320x240. 720x576like in some soft it out put size very poor resolution.
    u have choice u render it in- targa. jpg, or tiff file then import it as a sequence file then u will be getting out of ur problem.
  • Mon, Sep 8 2008 7:13 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,355
    • Points 60,470
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    You can adjust your render settings in Avid to HQ or standard quality...to use the effect render (in any given effect dialog) or override and render according to Avid settings...
    Mac Pro. QHD Ultra wide, thunderbolt LG monitor, MC 2019.6.0. Pro Tools 11 HD (Mbox 3 Pro), iPad Pro 12.9". 17" Macbook Pro i7. Dell Precision... [view my complete system specs]
  • Mon, Sep 8 2008 9:24 PM In reply to
    • Wm.Busby
    • LA, Cali
    • Posts 377
    • Points 4,405
    FWIW, I replied to the original poster's other thread on the same topic that there isn't a render quality mode in XDV 3.5. There must be something else that is awry here. I'm curious what this font is though.
    HP Z400 (W3520) 2.67 ghz quad core, 12GB ram, Quadro K2000 (Nvidia driver 310.90), Win 7 Pro 64, MC 5.5.3, Quicktime version 7.6.9, KVM switch, dual 20"... [view my complete system specs]
    Forum etiquette rule #1: FILL OUT SYSTEM SPECS IN PROFILE! :)
  • Wed, Sep 17 2008 6:53 PM In reply to
    • Kay Anderson
    • Toledo, Ohio
    • Posts 198
    • Points 2,610
     Well - never could figure why I was getting bad looking text after rendering -even though the frame rates in Boris & Avid are the same and any quality settings from both programs are at their highest.
    However - When I made a qt reference movie and the final dvd, both qt reference & final dvd looked great - no jagged edges.  So, I don't know why I'm suddenly getting jaggy text only when viewing from the Avid timeline.
    thanks -
