Latest post Fri, Sep 5 2008 2:32 PM by GBerge. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Sep 3 2008 9:26 PM
    • GBerge
    • Joined on Sun, Aug 17 2008
    • Posts 4
    • Points 85
    DVCPro HD 720p/23.976 Quicktime reference export
    Anybody come across this problem.  I'm trying to export a quicktime reference or a "same as source" quicktime file and all I get is a white screen.  The footage is from P2 cards shot on a HVX200.  I'm on MC 2.8.4 using a MacPro 3g Quad-Core using Quicktime 7.3.1.  Any thoughts or suggestions would be appreciated.
  • Wed, Sep 3 2008 9:29 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: DVCPro HD 720p/23.976 Quicktime reference export
    Are you viewing the QT on the same system as you export? If not, the white screen means that the codec you used to export is not present on the system from which you are playing back. If you are, then tell us what version of the software you are using and what QT version.
  • Wed, Sep 3 2008 9:35 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    BTW..the above was referenced to the SAS....
    IF the QT ref is doing it on the same system, then we need to knwo your software versions.
  • Wed, Sep 3 2008 9:54 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,289
    • Points 28,260
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    I believe you need to check the "Avid DV Codec” check box in your export settings.
  • Wed, Sep 3 2008 10:54 PM In reply to
    And then there's this little nugget.
    Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Thu, Sep 4 2008 2:03 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,289
    • Points 28,260
    I tried this with Media Composer 3.0 and it worked with both the reference and same as source QuickTime file. If the "Use Avid DV Codec" wasn't selected, the video would be a white frame.
  • Thu, Sep 4 2008 2:04 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Thanks for the help Bob. It's really appreciated.
  • Thu, Sep 4 2008 2:46 PM In reply to
    The issue I've seen others report is that when selecting the DV codec the footage looks crummy.
  • Thu, Sep 4 2008 2:47 PM In reply to
    http://community.avid.com/forums/p/62381/349912.aspx#349912
  • Fri, Sep 5 2008 2:32 PM In reply to
    • GBerge
    • Posts 4
    • Points 85
    Sorry bout the delayed reply.  I posted this and then had to jump on another job.
    I am on the same system that I'm exporting to.  The footage is 720p 23.98 from P2 (DVCPro HD) shot on an HVX200.  QT version is 7.3.1.  Media Composer 2.8.4.  I read the other posts from Bob and I'll try the DV codec thing.
