Latest post Fri, Aug 29 2008 11:52 PM by BobRusso. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Aug 29 2008 8:44 PM
    • Dcox
    • Joined on Fri, Aug 29 2008
    • Posts 1
    • Points 15
    How to finish in HD 23;98?
    PROBLEM:
    - We shot DVCPRO HD 24p (23;98 w pulldown in camera)
    - We digitized into a 30i project in Media Composer (this may been a mistake) but...
    - The real/ bigger problem is we have to get this project from Media composer and finish in Symphony Nitris so we can deliver HD CAM @ 23;98
    WHAT WE'VE DONE
    - We've tested dig'n the source tapes into Composer in both a 23.98 and 24p project but when we open said bins in Symphony an error message saying the clip frame rate and project frame rates don't match.
    - We are able to have the Symphony finish the 30i project but that leaves us with how to output HD@ 23;98
    QUESTIONS:
    - Is it an option to finish the edit in the 30i project and somehow do a frame rate conversion in symphony?
    - Is it an option to finish in 30i and teranex the master HD CAM?
    - We are using a Panasonic AJ HD 1200/1400 to dig.  Could the system frequency be affecting digin?
    - Is there any solution or are we F'd in the A?  I sure would appreciate it.
    Filed under: , , , ,
  • Fri, Aug 29 2008 11:52 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,265
    • Points 27,975
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: How to finish in HD 23;98?
    These are the directions on converting a 30i project to 24p: <http://www.24p.com/30_24.htm> You want to convert the project to a 23.976 project.
    This is how to digitize DVCPro HD tapes at 720p/23.976: <http://www.24p.com/VFR.htm>
    Avid has a 23.976 NTSC project type for this purpose.
