Latest post Tue, Jul 13 2010 10:15 PM by knoptop. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Aug 21 2008 7:38 PM
    Exporting a large sequence
     I have a 4 hour project on my timetine and am trying to export it so I can put it on a DVD. I can't export the whole thing as one file and if I break it up, the smaller files are 30 Gb a piece. Any suggestions on how I can get this thing exported and on a DVD?
    Processor: Intel Core i7 CPU X990 @ 3.47GHz Installed Memory (RAM) 24.0 GB Windows 7 64-bit OS Nvidia Quadro 5000 by PNY Avid MC 6.0 [view my complete system specs]
  • Thu, Aug 21 2008 7:55 PM In reply to
    Re: Exporting a large sequence
     4 hrs?  What is it, a mini-series?
    Export as a QTref and encode to DVD compliant MPEG-2 with a 3rd party encoder.
  • Thu, Aug 21 2008 8:02 PM In reply to
    When I do it as a Quick Time Reference file it says "Long GOP media cannot be exported using Quick Time Reference. Export as Quicktime Movie"
  • Thu, Aug 21 2008 8:16 PM In reply to
    That is because you have some kind of MPEG Long GOP media in your timeline  (HDV, IMX, etc). You need to transcode those files or mixdown your video tracks before exporting.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Fri, Aug 22 2008 9:45 AM In reply to
     Hei, 4 hours video on a 4,7 GB dvd disk is a lot to much, isn't it. My experience is that one our is optimal and for some projekts You can  have 1,5 h video, but then You have to produse the DVD with lower bitrate. 9300 Bit/s should be optimal and should play on most players.
    Dell Precision T3500 Graphics : 1GB Quadro Nvidia FX3800 - 2 DP, 1 DVI (1 DP-DVI, 1 DVI-VGA adapter)(MGRA16H) Processor : One Intel Xeon E5520(2.26GHz... [view my complete system specs]
  • Fri, Aug 22 2008 11:08 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,741
    • Points 61,845
     I think you'll find that a target video bitrate of less than 8000 is more likely to be compatible with most players. 9300 bps is really pushing it in my experience. I agree, 4 hours of video on a single layer DVD will typically result in rather poor quality.
    What is your source material, BTW. I first encountered the long-GOP QT Ref issue with HDV material. Doing a mixdown solved the problem, but it does use a lot of disk space since it will convert your material to a DNxHD codec (probably at 145 mbps compared to HDV at 25 mbps)...
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Aug 22 2008 1:46 PM In reply to
    All the source footage is in HDV. I cannot seem to get it to export as a quicktime reference to save me.
  • Fri, Aug 22 2008 2:33 PM In reply to
    snakebite404:
    Did you read my reply?
  • Fri, Aug 22 2008 2:42 PM In reply to
     I am doing a video mixdown right now. Thanks for your help!
  • Fri, Aug 22 2008 2:45 PM In reply to
    Yoy have to do a videomixdown and replace existing videotracks with this new mixdowntrack. Start with taking a kopi of Your sequence before you make a mixdown. Then You willl be able to export a quicktime reference
  • Tue, Jul 13 2010 9:57 PM In reply to
    • knoptop
    • Joined on Thu, Feb 5 2009
    • Ohio
    • Posts 12
    • Points 170
    I recently upgraded to MC5 and now I'm getting this error when trying to export my timeline.
    "Long GOP media cannot be exported using Quicktime Reference...."
    The problem is, I'm exporting using the same process as I did on my old system.
    Video Mixdown: Output to QT Reference and it's not allowing me to output.
    Any ideas what I need to do now?
    Avid Nitris DX - Media Composer 5 Windows 7 - 64-bit OS HP xw8600 Workstation Intel(R) Xeon(R) CPU X5460 @ 3.16GHz 3.17 GHz(2 Processors) 8.00GB... [view my complete system specs]
  • Tue, Jul 13 2010 10:15 PM In reply to
    • knoptop
    • Ohio
    • Posts 12
    • Points 170
    I figured out what I was doing wrong.   I didn't have the "USE MARKS" checked in the output menu.
    Wow, this MC5 has the strangest Default options.
