Latest post Sun, Sep 7 2008 8:20 PM by papu. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Aug 20 2008 11:50 PM
    • unihill
    • Joined on Wed, Aug 20 2008
    • Posts 5
    • Points 145
    Exception: Failed to initialize audio hardware - PLEASE HELP!
    Hi. I have the latest version of MC (2.8.4).
    I have Xp Professional and an Intel Dual CPU E2180. I have a motherboard with a Realtek HD soundcard which has all the latest drivers. I also have the latest version of quicktime.
    When Avid reaches 'Initialize audio' in the loading screen I get the error message "Exception: Failed to initialize audio hardware". I have tried changing the audio settings in my BIOS from 'auto' to 'AC97' however this simply stops the sound card from working (which means avid runs, but without sound!). I cannot change the settings on the realtek mixer confiog screen either.
    CAN ANYONE HELP AT ALL??!
  • Thu, Aug 21 2008 12:01 AM In reply to
    Re: Exception: Failed to initialize audio hardware - PLEASE HELP!
     Be advised that the latest version of Quicktime is not what you want. Look at the version matrix.
  • Thu, Aug 21 2008 12:10 AM In reply to
    • Posts 11,380
    • Points 233,240
     This may not be the problem in your case, but I can inform of the following (in my case)
    When I was using MC 2.8.2 I  had "Exception:........" when I had a USB mike connected for doing captures in Camtasia.
    After I upgraded to MC3 - the problem disappeared. I could use a USB mike and still have MC audio initialise.
    Who knows, maybe upgrading to MC3 would solve your problems too.
    Regards,
    Douglas
  • Thu, Aug 21 2008 12:13 AM In reply to
     I have also heard that on certain systems, webcams can cause an audio conflict, strange as that may sound.
  • Thu, Aug 21 2008 6:06 AM In reply to
    • jonlomas
    • Posts 20
    • Points 300
    I had this problem.  It was caused by the onboard Realtek audio.
    Sollution: buy a new audio card.
    Dell T5400 dimension, Mojo external SATA drives nvidia fx 5200 digidesign 002 [view my complete system specs]
  • Thu, Aug 21 2008 10:32 AM In reply to
    unihill:
    Search is your friend.  If you search for "realtek" you'll find a lot of posts with a lot of workarounds to try.
    good luck,
    Carl
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Sun, Sep 7 2008 8:20 PM In reply to
    • papu
    • Joined on Wed, Sep 3 2008
    • india
    • Posts 40
    • Points 405
     i had the same problem my mother bored is also having ac 97. that vertion of on board sound will not work . ask the hardwerer to up grage the bois are if u have programmed chip ac100 are upgrade chip put it on the sest otherwice fast work is buy the sound card. it will work 100% i tried it now also is running.
    Intel(R) Pentium(r) 3..40GHz. DDR2 ram 2Gb. 1TB of internel Hardisk. Xpress HD. Nvidia Graphic card. [view my complete system specs]
