Latest post Fri, Apr 17 2009 5:42 PM by wsimonett. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • Tue, Jan 27 2009 1:58 PM In reply to
    • JaapV
    • Joined on Tue, Jan 27 2009
    • Posts 2
    • Points 40
    Re: Keyspan not working
    I am using the 19HS, with the software from Keyspan.
  • Wed, Jan 28 2009 9:58 PM In reply to
    • Ixchiguan
    • Joined on Fri, Jan 26 2007
    • Wilmington, DE
    • Posts 16
    • Points 180
    I happen to have both a 19HS and USA-28X Keyspan and went through a thorough series of tests with both because I was told that AVID is now recommending only using the 19HS.
    I had been using the 28X with absolutely no problems but decided to see if I could transition over. I downloaded the latest drivers from the Keyspan site, uninstalled what I had on my computer, and then installed the newest driver---making sure the Keyspan 19HS was disconnected. I reconnected it---it didn't work. Went through a whole bunch of tests--still didn't work.
    Re-hooked up the 28X, kept the latest driver software in the MAC, made sure the deck configuration specifically referenced the serial port I was using in the Keyspan (NOT Key Serial 1), and everything works perfectly. At this point, I am sticking with the USA-28X until it dies.
    FYI--the AVID support person sent me a diagram of the Keyspan 19HS that I was supposed to have hooked to my MAC---guess what? the Keyspan shown in the diagram is a USA-28X---not at 19HS.
    Mike
    Symphony/MC 8.4.2, Nitris DX, Intel MAC 12-Core,64GB RAM, EVGA 980 TI Graphics Card, Firmtek e-sata drive housings (4 x 5 drives each) with Firmtek 6G... [view my complete system specs]
  • Wed, Jan 28 2009 10:03 PM In reply to
    28x is obsolete. You might be able to get it to work with enough time spent but it is also not frame accurate. Avid is recommending 19HS from now on.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Tue, Feb 3 2009 10:20 PM In reply to
    • Ixchiguan
    • Wilmington, DE
    • Posts 16
    • Points 180
    I know that's what AVID has said. However, your profile shows you are running a PC---I am running MC on a MAC Intel.....that could be it. I will try again tonight, although I called Keyspan (Tripplite) today and they said the 19HS is not checked out for MAC OS 10.5.6
    That could be it as well
  • Tue, Feb 3 2009 10:24 PM In reply to
    Ixchiguan:
    If you follow the link in my sig you will see I my company use both. That is just my personal system. I support dozens of Mac and Windows systems (and FCP as well).
  • Wed, Feb 4 2009 12:19 AM In reply to
    Gentlemen:
    I'm hooked up w/the Keyspan USA-28xb, and it works every time IF the computer will boot.  Every 4th time or so, the 'Curtain of Death' descends, and I push the button again...
    2 systems: Mobile: 16-inch Macbook Pro 2.4GHz 8-Core i9 w/64 gig RAM, 2TB SSD, OS 10.15.3 running MC 2020 Beta Legacy - MC v5.5.4, OS 10.5.8, QT 7.6, on... [view my complete system specs]
  • Fri, Feb 27 2009 12:04 PM In reply to
    I have the same problem. IThe 19HS outputs RS 232 signals, which I routes through a 232-to-422 converter, iMac sees it but considers it to be a modem that cannot be changed in the networks control panel.
    The LEDs on the 232 - 422 converter does not light up.
    Going insane on IMac 2,6 dual OS 10.5, MC 3.1.1, 3 g RAM
    Henrik Fleischer
    FEJØ
  • Fri, Feb 27 2009 3:54 PM In reply to
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 518
    • Points 5,965
    My Mac Pro sees it as a modem, too (under network control panel), but it has been working fine in MC, so I don't think that is the problem.  Does Keyspan Serial Assistant report any errors?  It should be installed in your applications folder.  Maybe the 232-432 converter is bad or installed backwards?
    Media Composer 8.3.1, OSX 10.9.5 [view my complete system specs]
  • Thu, Apr 2 2009 4:27 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Guess I'll try my old one first Surprise
    Dual 2 GHZ MAC.6 gig ram,3 gig hard drives, Avid w/ MOJO, FCP, Motion MBP Intel core 2 Duo,2.6 GHZ 4 gig ram, 17 inch Matte screen, Avid w/Mojo, &... [view my complete system specs]
  • Tue, Apr 14 2009 6:15 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Did you ever get it working?
  • Thu, Apr 16 2009 10:36 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    I just found out the Keyspan 28x is not supported anymore. I've been using the 28x for years and haven't had any problems with it. I read that the timecode might not be accurate so I want to switch to the now supported 19HS.
    I uninstalled my old keyspan driver. Then downloaded the new v2.5 driver for the 19HS from Keyspan website and installed. I can get deck control to work for a while but after I shutdown and startup computer again it seems to lose it's control?
    I've tried uninstalling and reinstalling several times now but I can't seem to get it to stick. What am I doing wrong? I'm using OS 10.5.6
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Fri, Apr 17 2009 5:36 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Solved. Everything seems to be working now after uninstalling and reinstalling 2.5 again and deleting from the network panel.
    Phoenix, Arizona
  • Fri, Apr 17 2009 5:42 PM In reply to
    • wsimonett
    • Madison, MS
    • Posts 140
    • Points 1,550
    Hmm, what version of MC are you using?
    Oh-never mind I see you are 3.5
    Bill
