Recently, I have a project wants to trigge deko play audio. When I use macro command, "audio_play" which shows "Command audio_play not found". This command seem doesn't exist. But I read all versions of deko macro reference, all shows the command exist. What is going on? Is that a optional function? I'm using Deko 3000, Deko 1000, PostDEKO.-------------------------------------------------audio_play Description: Play audio fileReturns: integer: duration (msecs) Syntax[$integer=] audio_play name= [gain=] -------------------------------------------------
I also turn to found other solutions. I found some commands also as a mystry as follow:deko_objex_play_audiodeko_objex_override_object_parameterdeko_objex_get_object_parameter_valueThose commands also won't work. (On Deko 3000)Is anyone who knows how to use those commands or have any sample.Thanks.
Hi Jerry,
Audio is part of the ClipDeko option. Deko Objex is also a separate option. From your description, it sounds like your system is not enabled with these options. You should contact your Avid sales rep/dealer for more info/pricing.
Regards,
Joann
