Latest post Wed, Apr 29 2009 2:27 PM by threedee. 13 replies.
Page 1 of 1 (14 items)
  • Fri, Aug 1 2008 8:29 AM
    • Rene Gomez
    • Joined on Sat, Jun 14 2008
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Best compression for export HDV sequence to DVD
    HI,
    I have  a sequence  in HDV. (4 min)
    I want to make a DVD standard (4:3) with this sequence, with the best  quality  as possible!!
    Some one how which one is the best compression or the best way for to do it ??
    Thank you!!!
    MacBook Pro 2.4 GHz Intel Core 2 Duo, 2GB RAM, NVIDIA GeForces 8600M GT 256 MB, 200 GB HD. OS X Leopard 10.5.4 & Avid Media Composer 3.0.5 [view my complete system specs]
  • Fri, Aug 1 2008 4:46 PM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Best compression for to export HDV sequence to DVD ???
    HI,
     Some one knows, which one is the best compression or the best way for to exporte this sequence to standard DVD ??
    Thank you!!!
  • Sat, Aug 2 2008 3:40 PM In reply to
    • avidmedic
    • Joined on Mon, Jan 30 2006
    • Atlanta, ga
    • Posts 58
    • Points 650
      Avid Certified User
    Re: Best compression for to export HDV sequence to DVD ???
    First of all, export from the Avid as a Quicktime referece.  This creates a file that is as native as possible.
    Then take the file to soreson squeeze.  Import the file in sorenson choose to create a MPEG2 video Large.  This will compress the file as MPEG-2 at around 7 megabits per second.  Slightly below average for a DVD, but a good spec.
    Then take the file into Avid DVD or any other DVD authoring to add menus and links.
    Or
    Go to your bin and select your sequence.  Go under file and choose send-to DVD.  It will do an all-in-one DVD that simply plays your video.  As of Verision 3.0 and higher.
    You name it, I've seen it. [view my complete system specs]
  • Sat, Aug 2 2008 3:43 PM In reply to
    • TerryO
    • Joined on Mon, Oct 24 2005
    • Oslo, Norway
    • Posts 253
    • Points 2,815
    avidmedic:
    HDV does not support QT reference. You will have to make a QT Movie...
    Work machines: 7 Avid Media Composer Adrenaline/Nitris DX/Mojo version 5.0.3.2 Avid Sympony Nitris DX v. 5.0.3.2 Interplay v. 2.1 and Unity Medianet ... [view my complete system specs]
  • Sat, Aug 2 2008 5:26 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: Best compression for export HDV sequence to DVD
     You don't really have a choice. Standard def DVDs are MPEG2 compression so you might as well just export as a QT ref and encode to MPEG 2 in the software of your choice.
  • Sun, Aug 3 2008 1:10 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,386
    • Points 97,010
    ...or do a video mixdown to a DNxHD codec and export a QTref of that.
  • Sun, Aug 3 2008 1:16 AM In reply to
    • jwrl
    • Posts 8,386
    • Points 97,010
    Rene, you have two threads on the same topic with the same title.  Please don't double post.  If you want to bring your topic to the top again open the existing thread and reply to it with the word "bump".
    Multiple posting lessens the chance of getting a response, because the more postings there are the less chance there is of a busy person finding yours.
  • Wed, Aug 6 2008 5:06 PM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    I got it, but HDV do not accept QT reference.....
    So, I have to make a QT movie, but with what kind of compressor and settings????
    Thank you!!
  • Wed, Aug 6 2008 9:06 PM In reply to
    • CoPARQ
    • Joined on Wed, Mar 8 2006
    • Wisconsin
    • Posts 81
    • Points 995
    Hello Rene:
    1. Do you have Sorenson Squeeze? If so, have you ever used it?
    2. Do you know how to create a video mixdown in Media Composer?
    3. Do you know how to send your Avid timeline to Sorenson Squeeze via Send to>  ?
    Newest System: Avid Nitris DX, HP xw8600, Intel Xeon X5450/3.00Ghz, WinXPSP3,Ciprico MediaVault U320, Quicktime v7.5.5, nVidia Quadro FX3700, 3.25 G RAM... [view my complete system specs]
    Colleen P.
  • Thu, Aug 7 2008 1:13 AM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Yeah I have Sorenson  Squeeze!!.and i know how to use it, but the problem is generate before, when I am exporting the sequence ( like: QT Movie, DNxHD o WMV, or what ever) It's freezing in 82% of the export process....all the times.
    The sequence have 6 min , 3 video HDV and SD and 2 audio tracks and 12 GB free in the disc.
  • Thu, Aug 7 2008 7:38 PM In reply to
    • ronn
    • San Diego
    • Posts 991
    • Points 12,445
    I've had excellent results by simply using "export HDV" to create an m2t elementary stream, then just bring that into MyDVD.10 - with 16x9 pixels, it plays widescreen on a widescreen TV but letterbox on a 4:3 TV. You can also change the settings in MyDVD to make a center crop 4:3.
    Media Composer 2018.9 with Intensity Pro 4K, Lenovo P500, Win-7 64 Prof. 16GB RAM, Nvidia 2200, Sony FS7, EX1, Ninja Assassin, Came-TV Mini2, Harley Dyna... [view my complete system specs]
    Ronn Kilby
    San Diego
  • Fri, Aug 8 2008 5:44 PM In reply to
    • Rene Gomez
    • Santiago, Chile.
    • Posts 58
    • Points 770
    Thank you !!.....I will try it !!
  • Fri, Feb 27 2009 12:52 AM In reply to
    Hey Ronn! I've tried to do just what you outline here but it took 15 hours to export a 1h15m sequence. Not only that but the resulting file was 13 GB. Does this sound correct? Also, will iDVD or DVD Studio Pro recognize this type of file?
    Filed under: , , , ,
  • Wed, Apr 29 2009 2:27 PM In reply to
    • threedee
    • Joined on Thu, Apr 13 2006
    • Netherlands
    • Posts 17
    • Points 200
    I wouldnt use squeeze cuz they don't use a real mpeg2 codec. export qt with dnxhd codec original size with 16;9 ratio. then use sonic to transcode also set to 16;9 and any tv will understand the file and play!
    tried everything this works like a charm!
    XP,Avid studio complete [view my complete system specs]
