Latest post Wed, Jul 30 2008 1:29 AM by DylanReeve. 4 replies.
  • Tue, Jul 29 2008 8:48 PM
    • swatchpost
    • Joined on Fri, Apr 4 2008
    • Los Angeles, CA
    • Posts 96
    • Points 1,165
    Exporting P2 on Avid for FCP output
    Hello All--
    I've searched the forums and the P2 workflows but haven't found the answer to my specific question:
    I'm running Avid Media Composer v2.8 on a Apple G5 Dual 2.3Ghz with QT 7.3 running OS X 10.4.11.  Everything's to Avid's specifications.
    I've got a 720p 23.976 Avid project with 720p60 P2 footage and want to export the best uncompressed quicktime I can to put into a Final Cut Pro system to layoff to DBeta.
    The SAS QT doesn't work at all—it gets hung up and doesn't export exactly what I want it to export, and I wondering if anyone has found a good codec to use for going from Avid 720p60 to FCP 720p60.  I would have initially thought the DVCPRO HD 720p60 codec would work fine, but I in the export settings I can't get it to get off "Medium" quality.  The Animation codec looks amazing—would that be the only way?
    Just want to see if anyone else has had any experience with this.
    Yusef
    MC v5.5.3, 2x2.93GHz 8Core Mac Pro, 32GB RAM, 10.7.5, QT v7.6.3 ; Avid MC v5.5.3, 2x3.06GHz MacBook Pro, 8GB RAM, 10.7.5, QT v7.6.3 [view my complete system specs]
    Filed under: , ,
  • Tue, Jul 29 2008 9:01 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: Exporting P2 on Avid for FCP output
     I would normally use the SAS but that means you would have to have the Avid codecs on the FCP system. Can't say why it's haning up on you unless there is a problem with some of the media in your sequence.
    My next choice would be Animation. Great looking codec..huge files sizes though.
  • Tue, Jul 29 2008 9:30 PM In reply to
    the 'DOG is correct, or you might try 'None'.  Even larger, but you'll know nothing has changed in your media.  I export using 'None' before crunching my :30 spots with Episode for DG DropBox transmission.  Huge, pristine files.
    2 systems: Mobile: 15-inch Macbook Pro Retina 2.6GHZ i7 w/16 gig RAM, 1TB SSD, OS 10.14.4 running MC 2018.12.3 Legacy - MC v5.5.4, OS 10.5.8, QT 7.6, on... [view my complete system specs]
    • swatchpost
    • Los Angeles, CA
    • Posts 96
    • Points 1,165
    I think I'm just going to go the Animation codec route because it's going to SD DBeta anyways.
    Thanks for your comment BLKDOG.
    Yusef
  • Wed, Jul 30 2008 1:29 AM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,460
    • Moderator: MCA Mac
    I've used Animation with sucess, and also used Blackmagic codecs.
    One potential gotcha is colour levels, I believe you have to export RGB levels to get the right colours out of FCP in that setup.
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
