Latest post Fri, Oct 15 2010 12:02 AM by Mir. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Jul 28 2008 9:31 PM
    Filmscribe Error - Lengths don't match
    Hi all,
    A filmscribe question - I was doing a change list between two sequences using FilmScribe v23.8.3 and got an interesting error.  It dumped me to the "Serious Program Error" and then said, "Error: Old and New sections should be of equal length, but are not:...this could be the result of incorrect KN values in one of the clips"  I went ahead and isolated the shots in question in the 2 sequences.  Firstly, it is the same shot, except 26 frames shorter in one of the sequences.  Secondly, there are no KN values for either shot (the show is not film, but, HD tape native).  And finally, the two shots were hand synced by me using 48fps material that I sped up and then synced with a .wav file from set.
    Any thoughts?
  • Tue, Oct 6 2009 10:50 PM In reply to
    • dyllio
    • Los Angeles
    • Posts 57
    • Points 590
    Re: Filmscribe Error - Lengths don't match
    Did you ever figure out what caused this error?  I'm now having the same issue using v25.04.4.   Same issue as you... it's getting stuck on the same clip that's shorter in the new sequence.   I'm in a film project but this is actually a VFX proxy that we created (exported Same as source with VFX burn-ins and then re-imported).
    Any thoughts or ideas are welcome.  thanks, DYLAN
    Mac Pro 2 x 2.66 Ghz 6-Core Intel Xeon, 16Gb RAM, Mac OS 10.7.2, MC6.0.1.1, NitrisDX [view my complete system specs]
  • Mon, Nov 9 2009 6:45 PM In reply to
    • mark.burton
    • London, UK
    • Posts 919
    • Points 11,235
    We're having this exact problem as well with VFX imports. If a sequence contains any clips without KN values, this error occurs. This never used to be an issue, so something has changed in the way FilmScribe is making change lists.
    I've sent this though to Avid along with an example bin for them to test. Fingers crossed a fix will come soon, like you guys, this is a big problem for us.
    We also tested on the very latest FilmScribe v26.0.3 which comes with MC 4.0.3 and the same problem happens there too.
  • Wed, Dec 2 2009 11:30 AM In reply to
    • mark.burton
    • London, UK
    • Posts 919
    • Points 11,235
    Still the same issue with the latest FilmScribe v26.0.4.
    Please can we have a fix for this, its all but killed our ability to acuratly tell the sound department what's changed.
  • Fri, Dec 4 2009 2:38 PM In reply to
    • glennlea
    • Avid Technology, Tewksbury
    • Posts 9
    • Points 125
    A fix is in the works.
    Glenn Lea Principal Engineer Avid Technology, Inc.
  • Fri, Dec 4 2009 2:49 PM In reply to
    • mark.burton
    • London, UK
    • Posts 919
    • Points 11,235
  • Tue, Dec 15 2009 6:51 PM In reply to
    • glennlea
    • Posts 9
    • Points 125
    The fix for this is in 3.5.9, released last week.
    Glenn
  • Tue, Dec 15 2009 7:28 PM In reply to
    • mark.burton
    • London, UK
    • Posts 919
    • Points 11,235
    Got it - all fixed!
    Thanks again for sorting this all out.
  • Fri, Oct 15 2010 12:00 AM In reply to
    • Mir
    • Joined on Sat, Nov 3 2007
    • Europe
    • Posts 45
    • Points 525
    And its back in version 27.0 for MC5.... argh
    .: www.PostOfficeFilms.com :. [view my complete system specs]
  • Fri, Oct 15 2010 12:02 AM In reply to
    • Mir
    • Europe
    • Posts 45
    • Points 525
    And its back in v27 for MC5... argh
