Latest post Sat, Jul 12 2008 7:48 AM by Jackyk. 2 replies.
  • Fri, Jul 11 2008 11:51 PM
    • Jackyk
    • nyc
    • Posts 217
    • Points 2,765
    Reconforming from SD project to 1080i
    Working on a 30 minute show with lots of cuts and its ready to be recaptured to HD.
    Renting the HDCAM deck next week and need to know if anybody has experience recapturing this footage and conserving all the cuts.
    Will it be a few frames off because the SD is at 29.97 and its changing to 1080i 59.94?
    I can reload the project on the HD system and basically recapture the source bin.
    Will this link to the edited sequence and show my edits?
    Imac 2017 - w ultimate z800 Z400 XW 8600 NITRIS [view my complete system specs]
    -MOJO SDI with AVID MC 7.0 -XW8400 - 4 Gig RAM -FX3500Nvidia GForce -Internal Sata sys drive,and a SATA 2 drive RAID -Addonics eSata controller ADSA3GPX1-2E on slot 4 -External Addonics Box w RAID 5 with five SATAII 300gig drives
  • Sat, Jul 12 2008 2:58 AM In reply to
    • B.J. Ahlen
    • Joined on Wed, Jun 4 2008
    • Santa Monica, Calif.
    • Posts 17
    • Points 205
    Re: Reconforming from SD project to 1080i
    "29.97" fps is the same frame rate as "1080i59.94."
    The first is "frames per second," the latter is fields per second, with odd + even fields making up a frame you get 29.97 frames per second (or to be exact 30*1000/1001 with NDF).
    Media Composer 3.0, HP xw8600 w/Quadro 3700, Mac Pro 8-core 10GB, MacBook Pro OS X 10.4, AJA IO, DL Extreme HD&SD, 4TB RAID, FCS2, Adobe Master Collection... [view my complete system specs]
  • Sat, Jul 12 2008 7:48 AM In reply to
    • Jackyk
    • nyc
    • Posts 217
    • Points 2,765
    I thought that, so it should be an exact to the frame recapture experience right?
