Latest post Wed, Jul 9 2008 9:56 PM by Larry Rubin. 3 replies.
  • Sun, Jul 6 2008 9:48 PM
    • Inbetween
    • Breda The Netherlands
    • Posts 40
    • Points 560
    Can't display color correction after upgrading to MC 3.0
    Hello! I have a serious problem after I upgraded from Avid Xpress Pro HD to MC 3.0. In the monitors or the video monitor (output through Avid Mojo), I can't see any adjustments made while correcting colors. Only when I make a correction and play the clip, I can see the adjustments made.
    I uninstalled the Nvdia Display Driver and reinstalled it, but the problem still persists. Any advice?
    Qualified Dell workstation, 3 GB Ram, Nvdia Quadro FX 1400
    Dell WS 690 dualcore 2,66, 4 GB RAM, 500 GB SATA raid 0. 2 x 750GB Nvidia 570 . Certified firewire PCI card. MOJO. MC 3.5.1 [view my complete system specs]
  • Sun, Jul 6 2008 9:51 PM In reply to
    Re: Can't display color correction after upgrading to MC 3.0
     First check and make sure "render on the fly" is active.
  • Wed, Jul 9 2008 9:19 PM In reply to
    • Inbetween
    • Posts 40
    • Points 560
     Hi Larry,
    Yes, that did it! Apparently this setting option is not activated when you do a fresh upgrade to MC 3.0. Hard to find either, tough its mentioned on page 412 in the manual...Smile Thanks anyway!
  • Wed, Jul 9 2008 9:56 PM In reply to
     You're welcome, Raoul. Glad that solved the problem for you. Ironically, "render on the fly" on both my Composer and Newscutter platforms CANNOT be de-activated!
