Latest post Thu, Dec 10 2009 4:12 PM by Jeroen van Eekeres. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Fri, Jun 27 2008 10:59 PM In reply to
    • ravidedit
    • Joined on Mon, Oct 24 2005
    • Northern Virginia/D.C.
    • Posts 667
    • Points 8,355
    Re: when to set Atto card to p2p prefered or arbitrated loop
    BLKDOG:
    None of us can possibly know everything. That's why we have this community.
    exactly.   I've been through Unity, PC and Mac ACSR but things change.  There's been things in the that Avid said was one way and then down the road said it should be done the opposite way.  Technology is always evolving , I'm just trying to keep up.
    2 MC DX Nitris, Pro Tools HD [view my complete system specs]
  • Fri, Jun 27 2008 11:22 PM In reply to
    Andrei Zhitkov:
     I thought you were the expert.
    Are you asking or just being an ass?
    MC 2020.6, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Sat, Jun 28 2008 1:35 AM In reply to
    Dom Q. Silverio:
    Andrei Zhitkov:
    I admitted my error in considering you an expert. Had I been asking, there would have been a question mark in the end of the sentence.
  • Sat, Jun 28 2008 2:42 AM In reply to
    So you where being an ass. Your mistake is the inability to read properly. If I admitted myself as the all-knowing-expert then you seem to have concluded that on your own, I would not be asking 'ACSR/expert' to chime in would I? If you concluded that before this thread then again you must have failed to read since I don't ever remember declaring myself as the all-knowing expert.
  • Sat, Jun 28 2008 7:58 AM In reply to
    Dom Q. Silverio:
    So you where being n ass. Your mistake is the inability to read properly. If I admitted myself as the all-knowing-expert you have to seem to have concluded on your own, I would not be asking 'ACSR/expert' to chime in would I? If you concluded that before this thread then again you must have failed to read again since I don't ever remember declaring myself as the all-knowing expert.
    Well, it's not often that I can master reading even a simple sentence, that much is true. Trying to find a fitting word can throw me in a mental stupor for ten to twenty minutes. Past Continuous Tense remains a mystery.
    I am also liable to assume that members of a professional forum would not post erroneous information knowingly and those who contribute a lot must be very knowledgeable without proclaiming themselves such, which is also stupid of me.
    Cheers!
  • Mon, Jul 7 2008 9:32 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,321
    • Points 25,890
    All this foolishness over a simple setting
    Vixel Switch is Arbitrated Loop
    Q-Logic is Point to Point Preferred.
    This is REGARDLESS of speed, tho typically the Qlogic is has only 4GB clients.   There are certain 2GB clients that MAY connect to a 4GB switch,  and the 3300 will need to be set to PTP.
    There are non-approved configurations out there with 2GB QLogics, but we won't get into them, as people might start throwing fecal matter about.
    JDS
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
    Filed under: , ,
  • Mon, Jul 7 2008 9:39 PM In reply to
    • ravidedit
    • Posts 667
    • Points 8,355
    thanks for clearing that up Doc.  And is it correct that lanshare connected fiber, the cards should always be set Arbitrated Loop?
  • Tue, Jul 8 2008 1:52 AM In reply to
    • ravidedit
    • Posts 667
    • Points 8,355
    OK, the official word from Unity support on the phone is
    PTP preferred for Q Logic switch
    PTP for 4gb Lanshare LP
    Arbritrated Loop for 2gb Lanshare or Vixel switch
  • Tue, Jul 8 2008 3:02 PM In reply to
    • Doc Avid
    • Posts 2,321
    • Points 25,890
    Bingo-  there are exceptions to this rule, tho they are for "off the reservation" configurations and not officially supported
    JDS
    ravidedit:
    Filed under: , , ,
  • Thu, Dec 10 2009 4:12 PM In reply to
    A small correction.
    ravidedit:
    I think it should be.
    PTP for 2gb Lanshare EX (without switch)
    Arbritrated Loop for (2gb Lanshare) with Vixel switch
    Jeroen van Eekeres
    www.mediaoffline.com
