Latest post Sat, Feb 6 2010 3:31 PM by Johnboy. 12 replies.
Page 1 of 1 (13 items)
  • Tue, May 13 2008 4:38 AM
    • Sims Carter
    • Joined on Thu, May 31 2007
    • Burbank, CA
    • Posts 217
    • Points 2,885
    CAPTURE TOOL problems
     Couple of problems:
    1)  The capture tool is having an extremely hard time finding pre-roll points (I tried this on several tapes) and says it FAILED.  (which is odd, because I'ver captured this footage before)
    2) when I hit "play" on the capture tool to get my deck to play the tape, my entire computer locks up so that I have to restart.  (I can't even hit "control/alt/delete")  This has also happened when I hit "play" on my deck while in capture mode.
    I have recently installed a new hard drive and re-installed Avid (from Xpress Pro to Media composer)
    Anyone have any solutions?
    Thanks!
    Windows 7 Professional 64-bit OEM SP1. Media Composer 7.0.2. Asus P9x79 Pro, Intel Core i7 3820 3.6GHz Quad Core 10MB 130W, 4 x Kingston DDR3-1600 4GB... [view my complete system specs]
  • Tue, May 13 2008 10:10 AM In reply to
    Re: CAPTURE TOOL problems
     you might try to trash all your settings files and mcstate, start avid and try again.
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Wed, May 14 2008 12:44 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 217
    • Points 2,885
     Thanks, jknikman!
    How / where do I trash all my settings files and mcstate?
  • Wed, May 14 2008 8:19 AM In reply to
    Sims Carter:
    This thread explains it pretty well.  If you have any follow up questions, post them back on this thread.
    good luck,
    Carl
  • Fri, May 16 2008 5:11 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 217
    • Points 2,885
     OK.
    In the Settings folder, I deleted MC State, Site Settings, and Site Attributes.
    I relaunched Avid.  Went into Deck Configuration and added Channel, added deck.
    But when I try to auto-configure it's saying "Auto-configure will not be successful because "" is currently not selected  Please select "" before auto-configuring this channel.
    What is ""?
    As of now, Avid isn't seeing the deck.
    Please le me know.
    Thanks!
  • Fri, May 16 2008 6:17 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 217
    • Points 2,885
    I also started a new project and a new user.  Still no success.
    Any ideas?
    Thanks for your help!
  • Fri, May 16 2008 10:12 AM In reply to
    I don't know exactly what you do but it seems to me that you didn't select the hannel before trying to autoconfigure. What I don't understand is why you want to autoconfigure as you already added a channel and a deck as you described.
    Actually I am not to fond of autoconfigure. Most of the time it defaults to a generic device. So I would advice to make a channel and add a deck to the channel by hand
  • Fri, May 16 2008 1:11 PM In reply to
    • evansmalley
    • Kansas City, MO (USA)
    • Posts 500
    • Points 6,370
    did you try re-registering the 'ol dvbuffers.ax scenario? sorry to suggest the obvious...
    Avid Media Composer 5.0.4, Windows7 Pro 64 bit sp1, i7-960 Intel processor, 8 gig DDR3 RAM, SSD 64gig boot drive, Samsung F3 1TB D drive, nVidia Quadro... [view my complete system specs]
  • Fri, May 16 2008 9:47 PM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 217
    • Points 2,885
     I finally got it working.
    I just powered everything down and unhooked everything, and then fired it back up.
    For no particular reason, it started working.
    Hilarious.
    Thanks everyone for your help!!!!!
  • Sat, May 17 2008 3:20 AM In reply to
    • evansmalley
    • Posts 500
    • Points 6,370
    welcome to the improbability machine of Avid
    the uncertainty principal applied in an application- how do they even do it?
    hope it's as much fun for you as it's been for me
    I really don't know if I can ever endure another update field trip though- so I'm just living in terror of the anticipated Media Composer install now... do I need this?
  • Sat, May 17 2008 4:39 AM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,184
    • Points 23,370
     no need to fret evan i just upgraded from axp5.8 to mc 2.8  went easy except i cant capture video thru my mojo but i added a second f/w card and it captures great through it so all is well in the upgrade world
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Sat, May 17 2008 7:07 AM In reply to
    Great. Happy editing!
  • Sat, Feb 6 2010 3:31 PM In reply to
    • Johnboy
    • Joined on Wed, Mar 1 2006
    • Posts 9
    • Points 95
    This is an old post now but thought I might as well share my cure for this problem.  My mistake was that when I set up the new channel in Deck Configuration I had chosen Firewire on COM4 instead of Firewire on OHCI.  Once I chose OHCI the problem went away
