Latest post Thu, Feb 21 2008 1:46 AM by jdw. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Jan 23 2008 8:19 PM
    • jdw
    • Posts 363
    • Points 4,435
    2.8 save bug?
    Just wondering if anyone out there is experiencing this...
    2.8 on 10.4.11
    when hitting command s to save, everthing saves properly. Don't change anything and hit command s again and it saves everything again. In the past, if there was nothng to save, it wouldn't rifle through all the open bins...
    MC 2018.9 OS 10.13.6 ISIS 7000 (2018.6.1) [view my complete system specs]
  • Wed, Jan 23 2008 8:43 PM In reply to
    Re: 2.8 save bug?
    Pretty sure it's always done that to me jdw.  My Avid has always been an equal opportuniy saver.
    Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Tue, Feb 19 2008 2:34 AM In reply to
    • double-g
    • Joined on Thu, Feb 2 2006
    • Posts 15
    • Points 195
    Re: 2.8 save bug?
    I'm pretty sure this is new behavior. Immediately after upgrading from 2.7.3 to 2.8, we saw every bin opened with the diamond icon in the bin's title bar. Figured it might be some change to the bin structure between 2.7 and 2.8, but even after everything has been saved over in 2.8, the behavior continues...
  • Tue, Feb 19 2008 2:56 PM In reply to
    Re: 2.8 save bug?
    Wanted to double-check this myself, running 2.8.
    If the project window is active, command+S will force an autosave of all bins, even if nothing has changed.
    If a bin is active, hitting command+S will ONLY save the bin if something changed.  (The diamond is not in the bin name if nothing has changed.)
    I don't know when this changed, but our Meridien systems don't act this way.  The only save when something changes, regardless of the active window.
    It's important to note because if you don't have enough bins setup for your Attic, you can very quickly only have a few minutes worth of changes if you actively save.
  • Tue, Feb 19 2008 3:49 PM In reply to
    Re: 2.8 save bug?
    My MC 2.7.5 system at home exhibits this exact behavior... I think it's been this way for awhile.
  • Tue, Feb 19 2008 3:55 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: 2.8 save bug?
    It SHOULD behave exactly as Kevin Describes above. The only time that currently saved bins should force-save again is when you select to save with the Project window active.
  • Thu, Feb 21 2008 1:46 AM In reply to
    • jdw
    • Posts 363
    • Points 4,435
    Re: 2.8 save bug?
    Select a bin in 2.8, make a change and save. It will save. Don't change anything. With that same bin selected, hit save again...it will save again. This is new.
