Latest post Fri, May 6 2011 3:13 AM by mistersq55. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Oct 24 2007 3:44 PM
    • dariv
    • Joined on Tue, Dec 5 2006
    • Posts 152
    • Points 2,275
    Trying to understand transition parameters
    Can someone please help me? I'm trying to understand the rules for adding quick transitions it seems that between some clips it won't allow me to add a transition, when I hit add quick transition the box comes up with 0 values and does not allow me to change the values. I've had this before but in this instance it is between a title and an image; I have added a similar transition earlier in the project, allbeit over two different video tracks.
    I believe I have enough disk space, so why can't I add a transition between these two clips?
    Avid xpress pro v5.5.3 Dell Inspiron 6400 (videoguys tweaked) 80gb hard drive 2gb RAM E:drive 300 gb Deck Varies [view my complete system specs]
    AKA Newbie Wan Kanewbi
  • Wed, Oct 24 2007 3:48 PM In reply to
    Re: Trying to understand transition parameters
    Sounds like you haven't left "handles" on the clips.  If you want to apply a transition, you can't cut in a clip from the head or tail frames.  You must set your marks inside, leaving sufficient frames as handles.
    (wwld)
  • Wed, Oct 24 2007 3:51 PM In reply to
    • riojapj
    • London, UK
    • Posts 137
    • Points 1,450
    Slip trim both segments away from the transition point and you'll have the media available to position the effect before, on or after the cut.
    Peej
    MC 8.10.0 Mac Pro (late 2013) CPU - 3 GHz 8-Core Intel Xeon E5 RAM - 64GB DDR3 GFX - AMD FirePro D700 6GB (x2) [view my complete system specs]
    Paul
  • Wed, Oct 24 2007 3:55 PM In reply to
    To ad to this: when putting a title in the timeline from your source monitor nuver put you inpoint in the source monitor at the stat of a clip. Yout titles are standard long enough sor put in a sec or 10 away from the start of the clip. Plenty of handle length that way.
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Wed, Oct 24 2007 4:09 PM In reply to
    • dariv
    • Posts 152
    • Points 2,275
    thanks guys that worked fine; does that rule only apply to titles and images?
  • Wed, Oct 24 2007 4:11 PM In reply to
    No. every transition effect between clips needs frames beyond in and out to be able to mix it one way or another with the frames of the previous or next clip.
  • Wed, Oct 24 2007 4:17 PM In reply to
    • dariv
    • Posts 152
    • Points 2,275
    Ah I see now, I've been told that before, but now I can 'see' it in my mind; thank you.
  • Thu, Oct 25 2007 12:54 AM In reply to
    The amount of handle you need to have is at least the length of the transition itself, especially in the case of "centered on the cut" transitions.  For example, a 30 frame "starting at the cut" transition needs no handle on the incoming scene, but needs 30 frames of handle on the outgoing scene.
  • Fri, May 6 2011 3:13 AM In reply to
    My quick transition icon won't even open, just "beeps"....
