Latest post Mon, Feb 25 2008 12:37 AM by pixels.paradise. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Jun 22 2007 4:30 PM
    • Bart
    • Posts 5
    • Points 75
    EDL Manager bug PAL/NTSC
    After installing the latest version of EDL manager (23.7) I'm having a problem importing EDL's ( cmx 3600) into my MC 2.7. When opening a PAL edl and creating a sequence of it it won't play because it says it is a NTSC sequence. At opening and importing I choose the correct frame rate (25) and project type (pal 25i). Even when I create an EDL myself from a PAL sequence, after opening and importing it back into the avid it's also converted to NTSC. I had the same problem before a year ago and fixed the problem by downgrading to 23.6.1 but it won't help this time.
    (this time I uninstalled the old version, removed the settings folder and installed 23.7)
    I have the same problem on a PC an MAC version of MC adrenaline in out company.
    Any idea?
    bart
  • Thu, Oct 11 2007 4:32 PM In reply to
    • John2072
    • Joined on Thu, Oct 11 2007
    • Paris
    • Posts 13
    • Points 155
    Re: EDL Manager bug PAL/NTSC
    I have the exact same problem with 23.6.6
    Each time I try to import an EDL at 25fps it thinks it's NTSC it's really annoying. EDL manager can only be used to export EDL at 25fps but cannot be used to (re-)import them...
    MC 8.6.4 / Windows 7 64bit [view my complete system specs]
  • Tue, Oct 16 2007 9:08 AM In reply to
    • John2072
    • Paris
    • Posts 13
    • Points 155
    So nobody knows how to fix this?
  • Tue, Oct 16 2007 1:02 PM In reply to
    • editdudes
    • Posts 112
    • Points 1,665
    Hi
    This is definitely a bug in EDL Manager, and it's been there for a while now.
    We filed a bug report with Avid Sweden at least a year ago, but nothing has
    happened yet, except for their sales staff calling us a few weeks ago asking
    how to get around the bug. I don't know why we're paying for Avid Assurance...
    There is a simple (but temporary) solution:
    Install an ancient version of edl manager. 22.2.1 should be ok.
    Best regards
    Johan Hansson, Sweden
    Symphony Nitris DX • MC Adrenaline DNxcel 5.5 • DaVinci Resolve • VirtualDub :) [view my complete system specs]
    E D I T   D U D E S
    Independent Post Production Services
    Malmö - SWEDEN
    www.editdudes.com
  • Tue, Oct 16 2007 1:38 PM In reply to
    • John2072
    • Paris
    • Posts 13
    • Points 155
    I just tried with 23.6.1 and I got the same problem the source EDL was :
    TITLE: UNTITLED1
    001  0001     V     C        00:00:02:11 00:00:04:17 00:00:02:11 00:00:04:17
    * FROM CLIP NAME:  0001.tif
    * FROM CLIP IS A STILL
    002  0002     V     C        00:00:08:09 00:00:11:07 00:00:08:09 00:00:11:07
    * FROM CLIP NAME:  0002.tif
    once imported it becomes :
    TITLE:   UNTITLED1
    FCM: NON-DROP FRAME
    001  0001     V     C        00:00:02:11 00:00:04:17 08:48:02:14 08:48:04:20
    * FROM CLIP NAME:  0001.TIF
    002  0002     V     C        00:00:08:09 00:00:11:07 08:48:08:12 08:48:11:10
    * FROM CLIP NAME:  0002.TIF
    if I try to import it in a 25i pal project it creates NTSC master clips...
  • Tue, Oct 16 2007 2:21 PM In reply to
    • editdudes
    • Posts 112
    • Points 1,665
    Sorry, wrong version...
    22.2.1 works for us, taken from XPPRO 5.2.4
    E D I T   D U D E S
    Malmö - SWEDEN
    www.editdudes.com
  • Tue, Oct 16 2007 3:02 PM In reply to
    • John2072
    • Paris
    • Posts 13
    • Points 155
    Ok thanks :)
    Does the fact of using an older version (than the one supplied with our installation of MC 2.6.6) cause other problems?
  • Tue, Oct 16 2007 3:28 PM In reply to
    • editdudes
    • Posts 112
    • Points 1,665
    We've been using 22.2.1 since MC 2.6, and it seems pretty stable.
    If it worries you, install it on a different machine and create an OMF from your edl.
    Update:
    Just installed EDL Manager 23.7.5 (comes with MC 2.7.5), and found that the
    ntsc/pal bug is still there. Downgraded to 22.2.1 again which solved the problem.
    E D I T   D U D E S
    Malmö - SWEDEN
    www.editdudes.com
  • Thu, Oct 18 2007 11:14 AM In reply to
    • John2072
    • Paris
    • Posts 13
    • Points 155
    We installed 22.2.1 on one of our stations to make tests. I noticed a difference between this old version and the new ones:
    The "Project Type" button is missing! So EDL manager is always set to30i  NTSC and we can't change it... The current project type is displayed when you (re)select the current settings in the EDL window.
    The "project type" button is still mentioned in the help though...
  • Wed, Feb 13 2008 2:04 PM In reply to
    • Sin
    • Joined on Wed, Feb 13 2008
    • Posts 1
    • Points 25
    If you decompose the "NTSC" sequence the EDL manager creates the clips are infact Pal. Once decomposed the sequence also becomes Pal and can be loaded into the timeline. Very strange.
  • Thu, Feb 21 2008 1:36 PM In reply to
    • Daniel
    • Joined on Tue, Feb 19 2008
    • Munich Germany
    • Posts 1
    • Points 5
    We are working with MCA 2.5.1 since its release date and used the EDL Manager delivered in this package without any problems so far, but on monday i was not able to create properly working EDLs. After checking the EDLs by re-importing them into our system the sequence always looks damaged. the original timeline length was exactly 38 seconds and after re-importing it only had 30 seconds and 2 frames. all dissolves were damaged and the timing of all edits was wrong. during hours of checking and re-installing the system, I had a look at the AVID forum and noticed that other users have the same problems for now nearly one and a half year. so i am wondering if there is an official solution from AVID available now. If there is no solution (patch, bugfix, etc.) I would like to know if there is any other way to get working PAL EDLs from my projects.
    I although tested making EDLs with MC Software 2.7.7 and the latest MC Software 2.8. but it was the same as with the MCA 2.5.1. So it seems that the problem also exists with the latest Software-Only versions of Media Composer and not only with the Media Composer Adrenaline.
    I am hoping someone has a quick solution as we need working EDLs.
    thank you in advance,
    Company: MCA 2.5.1 / Apple PowerPC G5 Dual 2.5 GHz 4 GB DDR SDRAM / Mac OS X 10.4.6 Freelance: MC Soft 2.8 / Apple Powerbook 1,67 GHz 2 GB DDR SDRAM... [view my complete system specs]
    good_old_denay
  • Mon, Feb 25 2008 12:37 AM In reply to
    Sin:
    sin is right. I experienced the same NTSC issue trying to make an EDL transfer from FCP to MCA. The imported PAL sequence in MCA was suddenly NTSC, but decomposing it results into a PAL sequence and batch digitize was frame accurate to the former FCP sequence.
    Well, as sin said, the solution is: DECOMPOSE IT!!!
    pixel
    iMac Mid 2016 / High Sierra 10.13.6 / 32 GB RAM / MCA 2019.12 / MojoDX / Adobe CC 2018 / MBPro Mid 2015 / High Sierra 10.13.6 / 16 GB RAM / MC 2019.12... [view my complete system specs]
    What is editing? It´s the process of transforming a collection of badly focussed or horribly framed shots containing reversed screen directions, flare and dirt into a smooth visual statement of the script... ... for which the director takes the credit!
