Latest post Mon, Oct 5 2009 3:27 PM by JP Edit. 7 replies.
  • Sat, May 26 2007 8:24 PM
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    OS X Cheat Sheet for Xpress Pro 5.7 & Media Composer 2.7
    Locked Contact
    The attached document is an unofficial Avid doc, compiled by the Avid Customer Support team. It is intended to help customers properly configure and troubleshoot Mac editing systems – both PowerPC and Intel-based Macs. Included are some tips and tricks to maximize performance and stability of your system. While this isn’t an official document, it’s meant to help people struggling with Mac’s and Adrenaline.
    Here's the link:
  • Tue, Feb 12 2008 4:44 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: OS X Cheat Sheet for Xpress Pro 5.7 & Media Composer 2.7
    There's a new Version Matrix Chart in the new KB. Very easy to use and understand. Just one thing I like about the new KB.
  • Mon, Oct 5 2009 2:59 PM In reply to
    • JP Edit
    • Elmhurst, IL
    • Posts 26
    • Points 290
    The current Version Matrix Chart for Xpress Pro only goes up to 5.8.3.  I have 5.8.4 -- is there any chance that this version will work on a G4 Powerbook (OS X 10.4.11, 1.67 MHz, ATI Mobility Radeon 9700 128 MB w/Quartz Extreme, 2 GB RAM, QT 7.5.5) with OS X 10.5.5?  Or is Tiger the highest OS AXP is compatible with?  My other option for upgrading OS seems to be a new Intel Mac and going to MC 4, an expensive proposition.  I've been holding out.
    Thanks.
    Machine Name: PowerBook Machine Model: PowerBook5,6 CPU Type: PowerPC G4 (1.2) Number Of CPUs: 1 CPU Speed: 1.67 GHz L2 Cache (per CPU... [view my complete system specs]
  • Mon, Oct 5 2009 3:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Although it's not officially in the chart, Anectdotal evidence is that 5.8.4 is fine wherever 5.8.3 will run.
  • Mon, Oct 5 2009 3:19 PM In reply to
    • JP Edit
    • Elmhurst, IL
    • Posts 26
    • Points 290
    Is there any anecdotal evidence that it will run on OS 10.5.5 or any version of Leopard?
  • Mon, Oct 5 2009 3:22 PM In reply to
    • Posts 10,284
    • Points 219,195
    JP Edit....
    Leopard was never tested on Xpress Pro - Tiger 10.4.11 was the last officially supported OS.
    marianna
  • Mon, Oct 5 2009 3:23 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Exactlly. Lots of Anectdotal evidence that it will NOT run on anything past 10.4.7.
  • Mon, Oct 5 2009 3:27 PM In reply to
    • JP Edit
    • Elmhurst, IL
    • Posts 26
    • Points 290
    I've had no problem with AXP 5.8.4 and OS X 10.4.11.  Thanks both of you.  Time to break the piggy bank.
    Jim
