BUMP!!!
Hi Kristin,It sounds like you are doing everything right, but here are a few things to check.
In your motion, be sure the Opacity parameter is active (the box should be checked). Also check that it is a Play On parameter, not a Play Off. Lastly, if you have the layer named, which is strongly advised for a MOS workflow, be sure that layer is the one selected in the pulldown menu for that action in the motion. Also double check that the duration of your motion wasn't mistakenly set to .1 which would basically be a cut.
You are correct in setting Sync with Effect for the clip, that will hold your clip until the motion is played. Once you get the dissolve on of the text working you may find you need to delay the dissolve on until the clip has resolved. To do that, scrub the CLIP to the frame that you want the motion completed by, make that the duration of the motion. Then scrub the clip to the frame that you want the dissolve on of the text to begin. Next scrub the motion to that time. Then click, hold & drag the left edge of the timing bar for the text layer to start at that time.
Good luck,
Mary Driscoll
