Latest post Fri, May 7 2010 6:22 PM by Johnla. 41 replies.
Page 3 of 3 (42 items) < Previous 1 2 3
  • Mon, May 11 2009 8:08 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    Re: BCC Glow effect not keyframeable?
    very good stuff g_f, thanks for sharing.
    -Matt M.
  • Mon, May 11 2009 10:04 PM In reply to
    mmullen:
    very good stuff
    I'm your man... Cool
    g_f
    P.S.: credits should go to Steve from splicehere, ofcourse!
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
  • Wed, May 27 2009 2:23 PM In reply to
    • Johnla
    • Joined on Fri, Oct 28 2005
    • Burlington, MA
    • Posts 54
    • Points 805
    • Avid Customer Service
      Avid Employee
    Earlier in this thread, there was discussion regarding a bug when keyframing BCC effects. Here is exactly what's happening.
    When using "Add to Active Parameter" for example, the BCC parameter being adjusted becomes deselected every time you change position in the timeline to add another keyframe, therefore, the new parameter value entered is not respected or remembered. That is where the limitation (or bug) is. If the parameter is supposed to be the 'active parameter', it should remain active until the user specifies otherwise. In other apps, the parameter remains truly active allowing you to move anywhere on the timeline and keyframe to your heart's content without having to constantly go back and forth to activate the same parameter you're working on.
    I have entered a bug report a while back, which I will modify with these findings. Thanks Matt and all for your input.
    Johnla
  • Wed, May 27 2009 4:49 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    This didn't occur to me now but I took a look and if you install and use the AVX 1.5 version of the effect it seems to work just fine.
    -Matt M.
  • Wed, May 27 2009 4:55 PM In reply to
    • Johnla
    • Burlington, MA
    • Posts 54
    • Points 805
      Avid Employee
    Yes, you are correct. AVX 1.5 was never the issue. This bug affects all Avid (including 3rd party like BCC) AVX 2.0 effects in Windows only. This bug does not affect AVX 1.5 effects in Windows, or AVX 1.5 and AVX 2.0 effects on Mac.
    Johnla
  • Thu, May 28 2009 2:50 AM In reply to
    Johnla thanks for getting back to us on this, much appreciated.
    Ra-ey
    Symphony Nitris v7, Media Composer v7, Artist Color, ISIS v4.1, Unity MediaNetwork v5.4, Sapphire v6.1, Boris Continuum Complete v8.1.1, AvidFX... [view my complete system specs]
    Media Composer 6 Certified User
    Media Composer 6 Certified Professional
    ra-eysaleh.com
    LinkedIn
    Showreel
  • Fri, May 7 2010 3:52 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    For future reference on this issue I uploaded a short video to show how to get around it/avoid it:
    http://community.avid.com/forums/post/470144.aspx
    -Matt M.
  • Fri, May 7 2010 4:41 PM In reply to
    • Johnla
    • Burlington, MA
    • Posts 54
    • Points 805
      Avid Employee
    Nice video, Matt! This is a good tutorial on using Advanced Keyframes. Yes
    The issue discussed previously in this thread still remains though - and that is the keyframe on a control slider becomes 'deselected' when you change position in the timeline when "Add to Active Parameter" is enabled. This behavior doesn't allow a new parameter adjustment to be remembered before moving forward to a new keyframe/adjustment. It is a UI limitation, not an operational issue.
    Johnla
  • Fri, May 7 2010 4:47 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    To be honest I have never run into that issue.  I'll take a look at it!
    -Matt M.
  • Fri, May 7 2010 5:58 PM In reply to
    • Johnla
    • Burlington, MA
    • Posts 54
    • Points 805
      Avid Employee
    I can webex and demonstrate for you.
    Johnla
  • Fri, May 7 2010 6:06 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    I think I know what you're talking about.
    You are referring to keyframing in the Record Monitor as opposed to actually in the effect editor?
    I'm not sure our schedules will line up to get a web ex session but I'll take a look.
    If this is the case it happens with all effects not just BCC?
    -Matt M.
  • Fri, May 7 2010 6:22 PM In reply to
    • Johnla
    • Burlington, MA
    • Posts 54
    • Points 805
      Avid Employee
    Taken directly from the defect report...
    "...affects BCC and some Avid effects (Xpress 3D) when using the Add Keyframe button. This is an AVX 2.0 only bug (does not affect AVX 1.5 effects)."
    Johnla
