Latest post Wed, Nov 11 2020 10:04 AM by Haliiles. 22 replies.
Page 1 of 2 (23 items) 1 2 Next >
  • Mon, Aug 10 2020 12:24 AM
    • DStone
    • Massachusetts
    • Posts 3,783
    • Points 48,355
      Moderator: MCA Mac
    Do NOT install Windows 10 Build 2004
    Windows 10 build 2004 is causing a lot of issues for a lot of people, not just for MC users. At this point I would advise NOT installing build 2004. If you have already installed it, and have a restore point, downgrade using the restore point. If you've installed it within the  past 10 days, you can roll back the installation to the previous version. If it's been over 10 days, or you did a clean install of build 2004, then you're out of luck. The only option in this case is to do a clean install of Windows 10 build 1909 and then reinstall all of your applications.
    If it's been less than 10 days, you can downgrade Windows 10 to a previous version. See the following Microsoft article:
    https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options
    and choose Remove an installed Windows update.
    Dave S.
  • Fri, Oct 2 2020 6:31 AM In reply to
    Windows 10 version
    Is this warning:
    "Do NOT install Windows 10 Build 2004" https://community.avid.com/forums/t/199889.aspx
    still valid?
    MB: ASRock Z390 Taichi Ultimate. CPU: Intel Eight Core i9-9900K/3600 16MB Cache, SATA Hard Disks Raid (2x4 TB), GPU 1200MHz. GC: Gainward RTX2080 Super... [view my complete system specs]
  • Fri, Oct 2 2020 8:22 AM In reply to
    Re: Windows 10 version
    My experience up until now.
    If running any older version of MC prior 2018.x make sure you are running the latest PACE ilok drivers or you will face BSOD's.
    Systems that upgraded from earlier versions like 1903, 1909 to 2004 sometimes produce odd performance behavior, I have not been able to find out why and there are plenty of people reporting the same in other (microsoft) forums.
    Clean formatted or 'reset not keeping any data' setups of windows 10 2004 are running fine including with older versions of MC as long as you update the Pace drivers directly after installing MC prior the first restart.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Fri, Oct 2 2020 10:29 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 693
    • Points 7,810
    has anyone had experience with win10 20H2 yet?
    symphony 2020.10- win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (456.71 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Sat, Oct 3 2020 8:48 AM In reply to
    I do not really understand, if the warning "Do NOT install Windows 10 Build 2004" ist still valid for MC 2020.9
  • Sat, Oct 3 2020 3:21 PM In reply to
    Roland Achini:
    I just updated the laptop in my specs to v2004 of Windows 10 Pro, and Media Composer 2020.9 seems to be working fine.
    This, of course, is not official word from Avid (the version matrix says Windows 10 Pro or Enterprise v1809 or later), so if you try it and your computer explodes, leaving you financially and creatively destitute, please do not blame me. I'm the one who risked it all, dove in without knowing how deep the water is, and updated to v2004 of Windows 10 just to provide an answer to this question.
    'I'd rather light a candle than curse your darkness.' - Gale Snoats, Raising Arizona
    Media Composer 2020.10 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Sat, Oct 3 2020 10:25 PM In reply to
    • touviere7
    • los angeles
    • Posts 693
    • Points 7,810
    touviere7:
    touviere7:
    if anyone wonder, win20H2 is the october release of win 2004 Idea
  • Sun, Oct 4 2020 12:37 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,382
    • Points 54,120
    I have had no showstopper issues. Only problem I had was Disk defrag/TRIMM function that was resolved Patch September.
    Using MC 20.10. Win 20H2  Avid FX6.4, Vegas Pro 17/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sun, Oct 4 2020 6:45 AM In reply to
    camoscato:
    Best thanks, camoscato!
    Roland
  • Sun, Oct 4 2020 8:30 AM In reply to
    Roland Achini:
    camoscato:
    Roland
    You're welcome, Roland! Smile
  • Mon, Oct 5 2020 9:40 AM In reply to
    I have 2 HP Z books and 2 HP Z400 workstations. All are now on Windows 10 build 2004
    All are behaving just fine.
  • Mon, Oct 5 2020 6:55 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,382
    • Points 54,120
    Windows 20H2 likely to drop within the next 2 weeks...will initiatally port through a manual Windows Update request.
  • Mon, Oct 5 2020 8:22 PM In reply to
    • scocklin
    • Maryland
    • Posts 673
    • Points 8,020
    Re: Do NOT install Windows 10 Build 2004
    Windows 2004 upgrade happened to me at a time when my edit work was nill.  When I did get some editing work I found Avid to be unstable,  mainly it would crash the computer when ever I exited out of Avid.
    I contacted Avid support and they said  "Based on your description it sounds like you have a Mojo or Nitris DX attached to the system." I disconected the Mojo box and everything worked.  I set avid to use the Blackmagic card on my system for video to my monitor.
    Avid support did get back to me and said Avid would not be fixing the problem, the support rep said that the Mojo units have reached end of life so eventually I'll start looking to upgrade my system.
    HP Z800 2x 3.46GHz Hex Core X5690, 96GB Ram, Windows 10, Samsung SSD 1TB, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K, Avid MC-2018.12.7 , MacBook... [view my complete system specs]
  • Tue, Oct 6 2020 4:00 AM In reply to
    • touviere7
    • los angeles
    • Posts 693
    • Points 7,810
    TVJohn:
    thanks, i will wait another month, hopefully after being able to read some additional feedback.
  • Fri, Oct 16 2020 1:57 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,783
    • Points 48,355
      Moderator: MCA Mac
    MS has resolved a number of issues in the 2004 release, including the defrag issue among others. Personally I'm still waiting for the next release, but if the current updated version is now working then you can try updating. You can always roll back within 10 days if you find any issues.
    Dave S.
