Latest post Mon, Aug 3 2020 3:22 PM by peter melaragno. 15 replies.
  • Sat, Jul 18 2020 5:27 PM
    HP Z400 vs HP Z420
    CURRENTLY: SYMPHONY 6.5 running on HP Z400 W3550. WIN7 64 BIT Quad Core 3.06GHz; 6GB MEM; 320GB 7200rpm internal nVidia FX4800; Integrated SATA RAID; MATROX MINI MAX 3-Port FireWire IEEE HBA Card.
    I have been using SYMPHONY 6.5 for several years now on my HP Z400 system detailed above. It has been getting slow but I do not want to upgrade SYMPHONY as it has been very stable. So I am looking at a new computer. After browsing the specs pages on Avid, I see that the HP Z420 is compatible with SYMPHONY 6.5, along with several other brands. As I been with HP for so long, I would like to stick with it. My question is whether the advantgae of Z420 over the Z400 is worth the trouble. The Z420 is Six Core 3.5 Ghz. The Z400 is Quad Core 3.06 Ghz. Will the Z420 be significantly faster? If not, can anyone recommend a better and compatible alternative?
    Thanks and all the best...
    NEW SYSTEM: HP Z820 SYMPHONY 6.5 w/WIN7 64 BIT. DUAL E5-2640 Six Core 2.5Ghz PROCESSORS. 16GB RAM. 1TB SSD. NVIDIA K4000. MATROX MINI MAX.. SYSTEM TWO... [view my complete system specs]
  • Sat, Jul 18 2020 9:23 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 440
    • Points 5,955
    Re: HP Z400 vs HP Z420
    I just retired 2-Z400a and I fried my Z800. I would think you need to get to a Z840 (which is what I'm going now). I can't imagine the Z420 could do well with 4K. You should upgrade to W10 too since W7 is EOL, esp. for security updates. (But is 6.5 compatible?) I just came off 6.5 a year ago. It was great and stable but I needed to support XAVC by going to 2018.10 and started to get some 4K. My Z800/M4000/96GB RAM was struggling with XAVC and 4K as well. I'm on 2020.6 now and learning the new interface. I was dealing with Jose at this company who does refurb HPs. So far he's been great to deal with and the prices are good. You can configure an entire refurb system to your liking on their site. Comes with 3 yr warrantee. https://tekboost.com/ After ordering a Z840 I started looking at refurb Z4, Z6 prices and they aren't bad either.
    MC 2020.06 w/Symphony option. BlackMagic DeckLink 12G, HP Z840 Dual 3.2Ghz/8 Core, 1TB SSD, 1TB Cache drive, 128GB Ram, Nvidia RTX2060 Super, BCC2020,... [view my complete system specs]
  • Sat, Jul 18 2020 10:06 PM In reply to
    I would swap the internal HDD for an SSD and up the RAM to 32 or 64GB. On 6.5, the extra cores won't matter much. CPu speed does. But I recall moving to SSD from HDD and the difference was stunning.
  • Sat, Jul 18 2020 10:14 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 440
    • Points 5,955
    On my Z800 I went from HDD to SDD and didn't notice much of an improvement. At only $120 it's not a bad way to go. I was surprised. And remember, SSDs dont die slowly, they just die. Make back-ups. ;0
  • Sun, Jul 19 2020 9:35 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 591
    • Points 6,995
    I also recommend the SSD and RAM upgrades.
    I'm also quite certain that we could upgrade the CPU to 8 cores for about 2-300 bucks used.
    After that you can use the machine for 5 years more if you want.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Sun, Jul 19 2020 5:06 PM In reply to
    The extras core spped of the HPZ420 will help. The extra cores will help if you have other apps ruuning.
    So I'd upgrade. Add the SSD boot drive. Add 2 oe 4 spinning media drives RAID 0 and max the RAM.
  • Sun, Jul 19 2020 5:22 PM In reply to
    The good change that happened between the 400s and the 420s was that PCIe3.0 became supported on the motherboard I believe, so newer graphics cards will take better advantage of the increased graphics bandwidth., although you may begin to face limits to the hardware you can install because of the PSU.  Honestly after all this time, a Z820 or or Z840 would provide you with more life and they are hardly expensive nowadays. I mean the 820 is 8 years old now, you can pick them up for less than £500 on ebay.  Treat yoself!
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Mon, Jul 20 2020 10:47 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    ripvanmarlowe:
    Yes, but you won't see real world performance differences from the increased bandwidth.
    What CPU model is currently in your machine? you can look that up in device manager.
  • Wed, Jul 22 2020 6:04 PM In reply to
    Hello to all who have posted to my query. Thank you. After looking at everything that you guys have advised, I decided that I needed to get a new machine. I especially after I discovered that LARRY Ruben, a moderator, had posted elsewhere saying that the Z820 is now in fact compatible with my symphony 6.5. And that is what I ordered from new egg, and exactly to the specs that Larry posted. Delivery on Friday. Thanks again. 💪🏻
  • Wed, Jul 22 2020 6:37 PM In reply to
    • Posts 11,317
    • Points 232,510
    Peter,
    Not sure if you are aware but we lost Larry many years ago.  He passed... but he was the MOST helpful, professional, sweetest man out there. Always had advice issued in a kind and nice way.
    Miss him terribly each and every day.
    I still use WWLD at the end of my posts to always remind me of how kind and helpful he was and to make sure I am the same.
  • Wed, Jul 22 2020 7:56 PM In reply to
    • Fazz Powell
    • Naples, FL
    • Posts 440
    • Points 5,955
    Thanks for the update I was curious how you were making out. You should be fine on the 820 and 6.5, I was running 2018.10 on my Z800 just fine, but 4K had to be proxy'd to HD. It put a smile on my face seeing Larry's name, he was a real gem and a fabric of this community. He's missed by all I'm sure.
  • Wed, Jul 22 2020 8:03 PM In reply to
    Thank you, Fazz. But forgive me, I did not know that Larry is no longer a moderator here. I'm hoping he has just retired or moved on to other things, but still here on this plane. Yes?
  • Wed, Jul 22 2020 8:13 PM In reply to
    peter melaragno:
    Unfortunately not, no. But his many contributions here are still helpful to many.
     https://community.avid.com/forums/p/119644/689833.aspx#689833
  • Wed, Jul 22 2020 8:15 PM In reply to
    Indeed  🙏
  • Wed, Jul 22 2020 9:34 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,765
    • Points 62,085
    Larry continues to touch our lives. I miss him.
    Steve
    ______________________
    www.nelliedogstudios.com
