Latest post Sat, Jul 25 2020 4:33 PM by jef. 7 replies.
  • Wed, Jul 1 2020 3:42 PM
    • keithkowal
    • Swampscott, MA
    • Posts 135
    • Points 1,985
    adobe Media encoder (ME) for 4k presets - for MC
    i'm still using sorenson for 1080 hd and that works great
    i export a REF file, like i use to do and use sorenson - gets me a mpg file  , which plays on my tv, np.
    but wanted to use adobe media encoder (cloud) instead 4k setting ,
    "same as project"  -> mp4,
    and many other presets (tried)
    the 4k encoding crashes , but it appears to start to work, but. and gives me a file
    procedurally i'm doing something wrong.   the file should be able to be played... on the pc, right?   NOPE
    in AVID i use export file (etc) do a video mixdown, etc.
    error shown by Adobe ME below.
    settings in ME:   4kUHD and High Quality 2160p 4k (tried both) with no success, presets with no mods
    Help required.
    what export setting should i use in avid?
    audio encode works in ME..
     - Source File: C:\Users\keithK\Desktop\MOROCCO_\all pictures SEQ.mov
     - Output File: C:\Users\keithK\Desktop\MOROCCO_\all pictures SEQ_1.mp4
     - Preset Used: High Quality 2160p 4K
     - Video: 3840x2160 (1.0), 29.97 fps, Progressive, Software Encoding, 01:03:10:26
     - Audio: AAC, 320 kbps, 48 kHz, Stereo
     - Bitrate: VBR, 1 pass, Target 80.00 Mbps, Max 96.00 Mbps
     - Encoding Time: 02:49:19
    07/01/2020 07:50:25 AM : Encoding Failed
    Error retrieving frame 68969 at time 01;38;24;27 from the file: C:\Users\keithK\Desktop\MOROCCO_2019\all pictures SEQ.mov, substituting frame 68968
     - Source File: C:\Users\keithK\Desktop\MOROCCO_2019\all pictures SEQ.mov
     - Output File: C:\Users\keithK\Desktop\MOROCCO_2019\all pictures SEQ_3.mp4
     - Preset Used: Match Source - High Bitrate
     - Video: 3996x2160 (1.0), 29.97 fps, Software Encoding, 01:03:10:26
     - Bitrate: VBR, 1 pass, Target 7.00 Mbps, Max 10.00 Mbps
     - Encoding Time: 01:49:03
    07/01/2020 10:29:16 AM : Encoding Failed
    File importer detected an inconsistency in the file structure of all pictures SEQ_1.mp4.  Reading and writing this file's metadata (XMP) has been disabled.
    2.4 ghz P7 / 3-1T HD / 20gbyte RAM / MC2018.1 [view my complete system specs]
  • Tue, Jul 14 2020 1:01 PM In reply to
    • Posts 11,268
    • Points 231,960
    Re: adobe Media encoder (ME) for 4k presets - for MC
    Hey keith
    Let me check it for you......
  • Tue, Jul 14 2020 1:08 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,694
    • Points 44,430
    keithkowal:
    Adobe Media Encoder does not support the use of a QT Ref file as a source.  You need to make some hard file.
    Jef
    Jef Huey
  • Tue, Jul 14 2020 10:44 PM In reply to
    • keithkowal
    • Swampscott, MA
    • Posts 135
    • Points 1,985
    You have been helpful to me before, thank you in advance
    all i want to do is export a 4k format from MC2020.x
    then use Media Encoder to keep the 4k format , etc.
    i don't see a 4k export file (in MC)  - seems obvious, but i just don't get it.
    please explain , thanks in advance.    if i need a plug-in, np.
    k
  • Fri, Jul 17 2020 1:34 AM In reply to
    • jef
    • Maryland
    • Posts 3,694
    • Points 44,430
    Look AMA file export.  Choose MXF Op1a and a reasonable data rate DNx HR codec.  That should do it.
    This is from memory - no software to check.  I do this all the time.
    Jef
    Jef Huey
  • Fri, Jul 17 2020 4:18 PM In reply to
    • jef
    • Maryland
    • Posts 3,694
    • Points 44,430
    Ok, sitting (virtually) in front of an Avid  2018.12.9 MC.  I have a UHD 23.976 project open.
    In my sequence bin I have the sequence I want output select and I right click / Output / Export to File / Export as / MXF OP1a / Video Compression (you can choose what you want) DNxHR HQ / Audio (as needed)
    You could also choose Avid Media Processor where I noted MXF OP1a above.  This will give you a different set of codec options.
    Either will give you a file with Audio and Video.  The OP 1a files are definitely read by Media Encoder.
    Jef
    Jef Huey
  • Sat, Jul 25 2020 4:28 PM In reply to
    • keithkowal
    • Swampscott, MA
    • Posts 135
    • Points 1,985
    this worked GREAT !    Thanks for the tips !    now  i have to change my import pics setting to get less compression  from LB to HQ... / any other tricks for best quality ?
  • Sat, Jul 25 2020 4:33 PM In reply to
    • jef
    • Maryland
    • Posts 3,694
    • Points 44,430
    keithkowal:
    Glad it helped.  As for "imported pics" it always is garbage in - garbage out.  Best to start with the highest quality still (I assume you are talking stills???) of at least the raster size as you final comp.
    Jef
    Jef Huey
