Latest post Sat, Jun 20 2020 10:50 PM by Dom Q. Silverio. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Jun 17 2020 12:32 AM
    • Steve
    • Los Angeles
    • Posts 95
    • Points 1,215
    What to use for H.264 encoding....
    What is everyone using to create h.264 movies?  My current workflow is to export a Quicktime Reference and use MPEG Stream Clip to compress it.
    This workflow works, but it's really slow.  Media Encoder does not support QT Reference so I've ruled that out.
    Also, since I'm using an Imac Pro with the Pro Vega 56 graphics card, I should be able to take advantage of the card for hardware encoding.  Radeon is very vague on how to take advantage of this....very.  Is anyone out there utilizing the Radeon Card for encoding?
    System Specs: ImacPro 3.2 GHz, 32 GB RAM, Radeon Pro Vega 56 OS 10.13.6 AVID MC 8.94 Black Magic 4k Extreme Areca 1882 SAS RAID Controller [view my complete system specs]
  • Wed, Jun 17 2020 3:26 AM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 47
    • Points 695
    Re: What to use for H.264 encoding....
    Since moving to Mac Pro 7,1 been using EditReady2 from Divergent Media;
    https://www.divergentmedia.com/editready
    Simple & fast, can't complain at all thus far.
    MC 2020.4|10.15.4|MacPro 16c|96gb|Pro Vega 2|Kona 5|Pegasus32 R8,R4i|Prism ADA8XR|XDR,LG 24MD4KL,Sony PVM2541 [view my complete system specs]
    I don't feel tardy...
  • Wed, Jun 17 2020 3:59 AM In reply to
    • mrtymcln
    • Joined on Tue, Aug 16 2016
    • Sydney, NSW
    • Posts 71
    • Points 780
    Compressor or Handbrake are the best options IMO.
    Media Composer 2019.6 with PF and SS | 2015 MacBook Pro with macOS 10.14.6 [view my complete system specs]
  • Wed, Jun 17 2020 6:52 AM In reply to
    Shutter Encoder. Made by editors for editors. Also does rewraps to differenr containers.
    As for QT Ref, you will at some point have to start to live without that. Do an internediate export from MC, using its new UME option to create either a MOV or Op1A MXF in DNx or ProRes. Very fast.
  • Wed, Jun 17 2020 1:22 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,439
    • Points 17,745
    For web-bound work, my normal output procedure now is to export an mxf op-1a file at a suitable DNxHD or DNxHR bitrate and then use Adobe Media Encoder to create h.264 mp4s.
    That said, Avid will now directly output h.264 into a .mov container but audio encoding remains limited to pcm.  With 32-bit quicktime no longer in the loop it's much faster than before.  Besides the labelled h.264 output, any of the Panasonic AVC options are h.264 under a different name
  • Wed, Jun 17 2020 6:47 PM In reply to
    • Steve
    • Los Angeles
    • Posts 95
    • Points 1,215
    Thanks!  I did not know that.
  • Wed, Jun 17 2020 9:22 PM In reply to
    • Steve
    • Los Angeles
    • Posts 95
    • Points 1,215
    I don't believe UME is an option since I'm using v 8.9.4.  I'm locked in to using the software version that the show is using.
    Thanks...
  • Wed, Jun 17 2020 9:24 PM In reply to
    • Steve
    • Los Angeles
    • Posts 95
    • Points 1,215
    Thanks....I tested this and Media Encoder ripped through it.  This seems to be the ticket unless someone has a  better workflow!
    Thanks!
  • Sat, Jun 20 2020 7:49 PM In reply to
    Would do a +1 for Shutter Encoder as not everyone has access to Adobe Media Encoder (Oh, I hate subscription only).
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2020.6, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Sat, Jun 20 2020 10:50 PM In reply to
    Steve:
    MC 2020 has a native H.264 export option. Limited control but great for screeners.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
